LCD Kit Instructions#
The LCD Kit includes everything to add a display to your hardware project. These instructions provide a step-by-step overview to build and configure your own Internet-connected weather station. This station displays a summary of the outside weather, temperature, and time. However, with this kit, you could display other bits of information besides weather.
Weather Station
As you follow these instructions, if you run into any issues, please refer to the Losant Documentation and the Losant Forums for help.
Materials#
Losant LCD Kit Materials
1. Environment Setup#
To properly program the kit's microcontroller, please follow the environment setup instructions. The NodeMCU included in this kit is programmed using the Arduino toolchain. These steps only need to be completed once, so if you've already done this for a previous kit, you can skip this step.
Additionally to the setup instructions, we need to install the LiquidCrystal_I2C library. This library will allow us to control LCD displays with the I2C protocol.
To install the LiquidCrystal_I2C library, open the library manager from the Sketch -> Include Library -> Manage Libraries menu and search for LiquidCrystal_I2C. There are a couple of similar libraries, so, you will want to choose the one by Frank de Brabander.
Liquid Crystal I2C Library
Once installed, your environment is ready.
2. Wiring#
Disconnect the microcontroller from USB before wiring.
In this step we're going to to connect the temperature sensor and LCD to the microcontroller. Below is the wiring diagram.
Wiring Image
  1. Push the microcontroller into terminals 1-15 on either side of the center line, which are rows b and i. The USB port should be facing away from the breadboard.
  2. Use a female-to-male jump wire to connect the VIN pin on the microcontroller j1 to the VCC pin on the LCD. The color of the jump wire doesn't matter.
  3. Use a female-to-male jump wire to connect the GND pin on the microcontroller j2 to the GND pin on the LCD.
  4. Use a female-to-male jump wire to connect the SCL pin on the microcontroller a14 to the D1 pin on the LCD.
  5. Use a female-to-male jump wire to connect the SDA pin on the microcontroller a13 to the D2 pin on the LCD.
  6. Connect the 3V3 pin from the NodeMCU (j5) to the positive rail with a jump wire.
  7. Connect the GND pin from the NodeMCU (j5) to the negative rail with a jump wire.
  8. Add the tmp36 temperature sensor to terminals f21, f22, and f23. It’s VERY IMPORTANT that the sensor is oriented the right way with the flat side facing the top of the board – towards column j.
  9. Connect the rightmost lead (f21) of the temperature sensor to the negative rail using a jump wire.
  10. Connect the leftmost lead (f23) of the temperature sensor to the positive rail using a jump wire.
  11. Connect the center lead (f22) to the A0 pin on the NodeMCU (terminal j15) with a jump wire.
Wiring Image
Once you have everything wired up, it's important that the two pins on the back of the LCD are tied together. These two pins power the backlight.
Backlight Pin
There is also a potentiometer on the back of the display. The potentiometer controls the contrast of the text on the LCD. So, once you start working on your device, if you can't see any text, try adjusting the contrast.
LCD Potentiometer
3. Losant Setup#
In this section, you’ll register for a Losant account, create your application, and add a device for your kit.
Create Account#
If you don't already have an account, navigate to Losant to create an account.
Create Application#
In Losant, every thing starts with an application. All devices and workflows belong to applications. So, create an application and you can name it whatever you want.
Create Application
Application Name
Add Device#
A device in Losant is a single thing or widget. A device could be car, thermostat, smart bulb, or any kind of custom gadget. Devices can contain many sensors or attached peripherals. In this example, our device is our weather station.
The next step is to register the device with the platform. Select Add Device from the Devices dropdown. Next, choose the Create Blank Device option.
Add Device Menu
Device Name
Device Settings
  2. "Description" can be left blank, or fill it with whatever you want.
  3. For "Device Type", leave "Standalone" selected.
  4. Add a device attribute with the type Number and the name tempF.
  5. Add a device attribute with the type Number and the name tempC.
The device attributes specify what state information the device reports. The firmware that you’ll flash in the following sections will report whenever a button is pressed, the temperature in Celsius (tempC), and the temperature in Fahrenheit (tempF). Device attributes are case-sensitive, so make sure to enter these exactly as they appear.
Device ID
Generate An Access Key#
Access Keys
Generate an access key that provides access to all devices in your application.
Token Restrictions
Access Token Popup
4. Flash the Firmware#
Get the Firmware#
Now let's get the firmware you'll be flashing to the device. Download and extract the following zip file to your computer. We'll be editing and opening these files using the Arduino IDE, so put it somewhere convenient.
https://github.com/Losant/losant-kit-lcd/archive/master.zip
If you're familiar with Git, you can also clone the repository from here:
Flashing#
Connect the microcontroller to your computer with the supplied USB cable. Make sure the device shows up under the Arduino IDE's Tools -> Port menu and it's selected. If the device does not show up, please review the Environment Setup guide.
With the Arduino IDE, use the File -> Open menu to navigate to where you downloaded and extracted the kit source code and open the file losant-kit-lcd/losant-kit-lcd.ino. Edit the following variables at the top of the file.
  1. WIFI_SSID = the name of your WiFi network
  2. WIFI_PASS = your WiFi password
  3. LOSANT_DEVICE_ID = set this to the ID you received after adding the device to the Losant application
  4. LOSANT_ACCESS_KEY = set this to the access key you generated after creating the Losant application
  5. LOSANT_ACCESS_SECRET = set this to the access secret you generated after creating the Losant application
Update Variables
Your code will automatically be saved as part of the upload process when it's flashed to the device. After editing the code, open the Arduino IDE's Serial Monitor and change the baud rate to 115200. The serial monitor can be opened using the button on the top right of the Arduino IDE or using the Tools -> Serial Monitor menu.
Open Serial Monitor
Serial Monitor Baud
The serial monitor won't print any information until we flash the device with the source code in the next step.
Upload the firmware to the device by clicking the Upload button or the Sketch -> Upload menu. This will take a few seconds and the microcontroller will rapidly blink a blue light while it’s uploading.
Upload Button
After the upload is complete, the Serial Monitor should start printing information about it connecting to WiFi and Losant. It may also print some garbage, but that's just part of the board booting up.
Serial Output
Every 15 seconds the firmware is publishing to Losant the inside temperature of the room you are in. Here is why that payload to Losant looks like:
{ "tempC": <value>, "tempF": <value> }
It’s now time to display the rest of the weather data on the LCD screen.
5. Displaying Data on LCD#
As we've seen, Losant can capture state from the device. Losant can also send commands back to the device. In this case, we can send a command to the device with information we want it to display on the screen. In the firmware we flashed, there is a function called handleCommand:
void handleCommand(LosantCommand *command) {
  Serial.print("Command received: ");
  Serial.println(command->name);
  JsonObject& payload = *command->payload;
  if (strcmp(command->name, "refresh") == 0) {
    payload.printTo(Serial);
    // Clear the screen.
    lcd.clear();
    // Move the cursor to the start of the first line and print the text.
    lcd.setCursor(0,0);
    lcd.print(payload["L1"].asString());
    // Move the cursor to the start of the second line and print the text.
    lcd.setCursor(0,1);
    lcd.print(payload["L2"].asString());
The Losant Arduino firmware uses MQTT to communication with devices. Once an MQTT payload is received, handleCommand will be called. As you can see, we are looking for a command called refresh. If received, it will print L1 (Line One) and L2 (Line Two) to the LCD screen. This allows us to easily edit and control what the screen displays with out having to continuously flash the device with new firmware.
When sending larger payloads, you may have to change a parameter to allow MQTT to send larger packet sizes.
We have the inside temperature data - this is the temperature displayed in the Serial output. Now, we need to get the outside weather and time to display it. We will use a workflow for this.
Create a Workflow#
Workflows are the primary way for your devices to communicate with each other and other services. Workflows allow you to trigger notifications, create events, send commands, and many more. Workflows are basically the brains of your connected solution.
As a way to get up and running as fast as possible, we've provided you a workflow you can import. In the firmware zip file you downloaded earlier, there is a file named lcd-weather-station.flow. Import this file as a new workflow in your application using the import button on the View All Workflows page.
Import Workflow
Once imported, your workflow should look like the following:
Imported Workflow
Workflow Overview#
Let's talk about how this workflow works. All workflows start with a trigger. For this example, we have three triggers. When the device is started, we want to grab the weather and send it down to the device. We also need a timer to send data periodically. Lastly, we can configure a button to send the data on demand. We simply want this workflow to run and send time and weather data to our device.
Node Errors#
You'll notice that there are two nodes that have small error icons: the On Connect trigger and the Device Command output. These have errors because they need a device to be configured. Click on each of them and select your device from the dropdown. The two nodes should be configured for the same device.
Nodes with Errors
Lets walkthrough the other nodes and make sure that they are properly configured.
Timer#
A Timer node will trigger on an interval you define.
Workflow Timer
For reasons explained later, we will use this workflow to simulate time. So, we need it to run once a minute.
HTTP#
The HTTP node allows us to connect to external services. To get the outside weather data, we can use the Dark Sky API.
Workflow HTTP
Sign up for Dark Sky API#
Signing up for the Dark Sky API is extremely simple and only requires an email address. Once you sign up you'll be provided an API key. Keep this handy for future steps. This API key gives you 1,000 requests free each day, which is more than enough for this application.
Dark Sky API Key
No, sorry, the API key in the above screenshot won't work.
Click the HTTP node to configure it. There are two important configuration options for the HTTP node. The first is the URL and the second is where to store the result. The URL will be Dark Sky's API endpoint:
https://api.darksky.net/forecast/APIKEY/LATITUDE,LONGITUDE
The APIKEY should be replaced by the key you obtained in step 1 after registering for Dark Sky. The LATITUDE and LONGITUDE are the coordinates, in decimal degrees, of the location to request. MyGeoPosition.com is a neat tool to get these coordinates if you don't have them handy. Here's the coordinates of Losant's headquarters if you'd like to use these:
https://api.darksky.net/forecast/APIKEY/39.1119359,-84.51254
The second required configuration parameter for this HTTP node is the location on the payload to put the result. Workflows work by passing a payload through each node in the workflow. Nodes can add, remove, or modify the payload as needed as it flows through them. In this case, we're going to add a weather field to the payload that will hold the response from the Dark Sky API.
Function#
The NodeMCU does not have an internal clock. So, keeping time is a little challenging. It is possible to configure it to be synced with an NTP server but, for time's sake, we can simulate time in a workflow. Losant has a Function node that we can use to run our own JavaScript to get the time.
Workflow Function
In our Function node, we have this code:
var d = new Date();
d.setHours(d.getHours() - 5); // Time is in UTC. So, we subtract 5 to get the correct time. Five is the offset for EST time.
d = d.toLocaleTimeString().replace(/:\d+ /, ' '); // current time, e.g. "1:54 PM"
payload.time = d // append time to payload
Time is now appended to our payload to send later.
Math#
In many situations, we need to do some simple calculations to our data before sending it some where else. In this case, since we have limited space on the LCD screen, we want our temperatures to be whole numbers, not decimals. Losant provides a Math node to solve this problem.
Workflow Math
In our math node, we can round the temperature:
round({{ weather.body.currently.temperature }})
weather.body.currently.temperature will now be rounded in our payload.
Device Command#
Now that we have all the data, we need to format it and send it to the device. For this purpose, we use the Device Command node.
Workflow Device Command
As seen earlier, we need to send the device L1 and L2. In this node we can configure a JSON payload that contains both:
  "L1": "{{ time }}      {{ weather.body.currently.temperature }}",
  "L2": "{{weather.body.currently.summary}} "
Deploy#
With all fields configured you can now deploy this workflow and begin sending data to your device.
Deploy Workflow
Once you deploy, after one minute, you should see the weather information being displayed on the LCD.
Kit Complete
7. What's Next?#
This workflow is just a starting point. Losant can connect this device to many different outputs and other 3rd-party services. As an additional challenge, see if you can figure out how to Slack a message to your office whenever it gets to hot.
Since the firmware accepts line one and line two, you can send it any data for all different types of projects!
