Application Certificates Actions
https://api.losant.com/applications/APPLICATION_ID/certificates
Below are the various requests that can be performed against the Application Certificates resource, as well as the expected parameters and the potential responses.
Returns the application certificates for an application
GET https://api.losant.com/applications/APPLICATION_ID/certificates
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, applicationCertificates.*, or applicationCertificates.get.
| sortField | N | Field to sort the results by. Accepted values are: certificateInfo.commonName, status, id, creationDate, lastUpdated | certificateInfo.commonName | sortField=status |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: certificateInfo.commonName, status | filterField=status | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=the*status |
| 200 | Application Certificates | Collection of application certificates |
Create a new application certificate for an application
POST https://api.losant.com/applications/APPLICATION_ID/certificates
all.Application, all.Organization, all.User, applicationCertificates.*, or applicationCertificates.post.
The body of the request should be serialized JSON that validates against the Application Certificate Post schema. For example, the following would be a valid body for this request:
"description": "An example new certificate description",
"certificate": "-----BEGIN CERTIFICATE-----\nMY_SSL_CERTIFICATE\n-----END CERTIFICATE-----",
"filterType": "all",
"pubTopics": [],
"subTopics": []
-d '{"description":"An example new certificate description","certificate":"-----BEGIN CERTIFICATE-----\nMY_SSL_CERTIFICATE\n-----END CERTIFICATE-----","filterType":"all","pubTopics":[],"subTopics":[]}' \
| 201 | Application Certificate | Successfully created application certificate |
Schema for a single Application Certificate
Application Certificate Schema
- ▶{} 13 keys
Application Certificate Example
- ▶{} 11 keys
- "5cd02a50df66feb0994c7196"
- "active"
- "An example certificate description"
- ▶{} 6 keys
- "all"
- [] 0 items
- [] 0 items
Schema for the body of an Application Certificate creation request
Application Certificate Post Schema
- ▶{} 8 keys
Application Certificate Post Example
- "An example new certificate description"
- "-----BEGIN CERTIFICATE-----
MY_SSL_CERTIFICATE
- "all"
- [] 0 items
- [] 0 items
Schema for a collection of Application Certificates
Application Certificates Schema
- ▶{} 10 keys
Application Certificates Example
- ▶{} 8 keys
- 1
- 4
- 1
- 0
- "key"
- "asc"
