Experience Domains Actions
https://api.losant.com/applications/APPLICATION_ID/experience/domains
Below are the various requests that can be performed against the Experience Domains resource, as well as the expected parameters and the potential responses.
Returns the experience domains for an application
GET https://api.losant.com/applications/APPLICATION_ID/experience/domains
all.Application, all.Application.cli, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.cli, all.User.read, experienceDomains.*, or experienceDomains.get.
| 200 | Experience Domains | Collection of experience domains |
Create a new experience domain for an application
POST https://api.losant.com/applications/APPLICATION_ID/experience/domains
all.Application, all.Organization, all.User, experienceDomains.*, or experienceDomains.post.
The body of the request should be serialized JSON that validates against the Experience Domain Post schema. For example, the following would be a valid body for this request:
"domainName": "my.domain.example.com",
"sslCert": "-----BEGIN CERTIFICATE-----\nMY_SSL_CERTIFICATE\n-----END CERTIFICATE-----",
"sslKey": "-----BEGIN PRIVATE KEY-----\nMY_SSL_KEY\n-----END PRIVATE KEY-----",
"version": "develop"
-d '{"domainName":"my.domain.example.com","sslCert":"-----BEGIN CERTIFICATE-----\nMY_SSL_CERTIFICATE\n-----END CERTIFICATE-----","sslKey":"-----BEGIN PRIVATE KEY-----\nMY_SSL_KEY\n-----END PRIVATE KEY-----","version":"develop"}' \
| 201 | Experience Domain | Successfully created experience domain |
Experience Domain
Schema for a single Experience Domain
Experience Domain Schema
- ▶{} 9 keys
Experience Domain Example
- ▶{} 7 keys
- "58c1de6c8f812590d8e82980"
- "my.domain.example.com"
- "develop"
Schema for the body of an Experience Domain creation request
Experience Domain Post Schema
Experience Domain Post Example
- "-----BEGIN CERTIFICATE-----
MY_SSL_CERTIFICATE
- "-----BEGIN PRIVATE KEY-----
MY_SSL_KEY
- "develop"
Experience Domains
Schema for a collection of Experience Domains
Experience Domains Schema
Experience Domains Example
- 1
- 1
