Workflow Version resource, as well as the expected
A valid api access token is required to access this endpoint. The token must
all.Application, all.Organization, all.User, flowVersion.*, or flowVersion.delete.
Path Component
Description
Example
APPLICATION_ID
ID associated with the application
575ec8687ae143cd83dc4a97
FLOW_ID
ID associated with the flow
575ed18f7ae143cd83dc4aa6
FLOWVERSIONID
Version ID or version name associated with the flow version
675ed18f7ae143cd83dc4bb7
Name
Required
Description
Default
Authorization
Y
The token for authenticating the request, prepended with Bearer
Get information about errors that occurred during runs of this workflow version
GET https://api.losant.com/applications/APPLICATION_ID/flows/FLOW_ID/versions/FLOW_VERSION_ID/errors
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, flowVersion.*, or flowVersion.errors.
Path Component
Description
Example
APPLICATION_ID
FLOW_ID
FLOWVERSIONID
Name
Required
Description
Default
Example
duration
N
Duration of time range in milliseconds
86400000
duration=86400000
end
N
End of time range in milliseconds since epoch
0
end=0
limit
N
Maximum number of errors to return
25
limit=25
sortDirection
N
Direction to sort the results by. Accepted values are: asc, desc
desc
sortDirection=desc
deviceId
N
For edge workflows, the Device ID to return workflow errors for. When not included, will be errors for all device IDs.
deviceId=575ed18f7ae143cd83dc4bb6
Name
Required
Description
Default
Authorization
Y
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, flowVersion.*, or flowVersion.get.
Path Component
Description
Example
APPLICATION_ID
FLOW_ID
FLOWVERSIONID
Name
Required
Description
Default
Example
includeCustomNodes
N
If the result of the request should also include the details of any custom nodes referenced by the returned workflows
false
includeCustomNodes=true
Name
Required
Description
Default
Authorization
Y
Retrieve the recent log entries about runs of this workflow version
GET https://api.losant.com/applications/APPLICATION_ID/flows/FLOW_ID/versions/FLOW_VERSION_ID/logs
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, flowVersion.*, or flowVersion.log.
Path Component
Description
Example
APPLICATION_ID
FLOW_ID
FLOWVERSIONID
Name
Required
Description
Default
Example
limit
N
Max log entries to return (ordered by time descending)
1
limit=10
since
N
Look for log entries since this time (ms since epoch)
since=1465790400000
Name
Required
Description
Default
Authorization
Y
all.Application, all.Organization, all.User, flowVersion.*, or flowVersion.patch.
Path Component
Description
Example
APPLICATION_ID
FLOW_ID
FLOWVERSIONID
Name
Required
Description
Default
Example
includeCustomNodes
N
false
Name
Required
Description
Default
Authorization
Y
The body of the request should be serialized JSON that validates against
the Workflow Version Patch schema. For example, the following would be a
valid body for this request:
{"notes":"Updated workflow version notes","enabled":false}
Get statistics about workflow runs for this workflow version
GET https://api.losant.com/applications/APPLICATION_ID/flows/FLOW_ID/versions/FLOW_VERSION_ID/stats
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, flowVersion.*, or flowVersion.stats.
Path Component
Description
Example
APPLICATION_ID
FLOW_ID
FLOWVERSIONID
Name
Required
Description
Default
Example
duration
N
86400000
duration=86400000
end
N
0
end=0
resolution
N
Resolution in milliseconds
3600000
resolution=3600000
deviceId
N
For edge workflows, the device ID to return workflow stats for. When not included, will be aggregate for all device IDs.
Name
Required
Description
Default
Authorization
Y
