Instance Organization resource, as well as the expected
A valid api access token is required to access this endpoint. The token must
all.Instance, all.User, instanceOrg.*, or instanceOrg.delete.
Path Component
Description
Example
INSTANCE_ID
ID associated with the instance
575ec8687ae143cd83dc4a97
ORG_ID
ID associated with the organization
575ed6e87ae143cd83dc4aa8
Name
Required
Description
Default
Authorization
Y
The token for authenticating the request, prepended with Bearer
Returns device counts by day for the time range specified for this organization
GET https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/deviceCounts
all.Instance, all.Instance.read, all.User, all.User.read, instanceOrg.*, or instanceOrg.deviceCounts.
Path Component
Description
Example
INSTANCE_ID
ORG_ID
Name
Required
Description
Default
Example
start
N
Start of range for device count query (ms since epoch)
start=0
end
N
End of range for device count query (ms since epoch)
0
end=1465790400000
Name
Required
Description
Default
Authorization
Y
curl-H'Content-Type: application/json'\-H'Accept: application/json'\-H'Authorization: Bearer YOUR_API_ACCESS_TOKEN'\-X GET \
all.Instance, all.Instance.read, all.User, all.User.read, instanceOrg.*, or instanceOrg.get.
Path Component
Description
Example
INSTANCE_ID
ORG_ID
Name
Required
Description
Default
Example
summaryInclude
N
Comma-separated list of summary fields to include in org summary
summaryInclude=payloadCount
Name
Required
Description
Default
Authorization
Y
Returns notebook execution usage by day for the time range specified for this organization
GET https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/notebookMinuteCounts
all.Instance, all.Instance.read, all.User, all.User.read, instanceOrg.*, or instanceOrg.notebookMinuteCounts.
Path Component
Description
Example
INSTANCE_ID
ORG_ID
Name
Required
Description
Default
Example
start
N
Start of range for notebook execution query (ms since epoch)
start=0
end
N
End of range for notebook execution query (ms since epoch)
end=1465790400000
Name
Required
Description
Default
Authorization
Y
all.Instance, all.User, instanceOrg.*, or instanceOrg.patch.
Path Component
Description
Example
INSTANCE_ID
ORG_ID
Name
Required
Description
Default
Example
summaryInclude
N
Name
Required
Description
Default
Authorization
Y
The body of the request should be serialized JSON that validates against
the Instance Owned Organization Patch schema. For example, the following would be a
valid body for this request:
Returns payload counts for the time range specified for all applications this organization owns
GET https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/payloadCounts
all.Instance, all.Instance.read, all.User, all.User.read, instanceOrg.*, or instanceOrg.payloadCounts.
Path Component
Description
Example
INSTANCE_ID
ORG_ID
Name
Required
Description
Default
Example
start
N
Start of range for payload count query (ms since epoch)
start=0
end
N
End of range for payload count query (ms since epoch)
end=1465790400000
asBytes
N
If the resulting stats should be returned as bytes
false
asBytes=true
Name
Required
Description
Default
Authorization
Y
Returns payload counts per resolution in the time range specified for all application this organization owns
GET https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/payloadCountsBreakdown
all.Instance, all.Instance.read, all.User, all.User.read, instanceOrg.*, or instanceOrg.payloadCountsBreakdown.
Path Component
Description
Example
INSTANCE_ID
ORG_ID
Name
Required
Description
Default
Example
start
N
start=0
end
N
end=1465790400000
resolution
N
Resolution in milliseconds. Accepted values are: 86400000, 3600000
86400000
resolution=86400000
asBytes
N
false
asBytes=true
includeNonBillable
N
If non-billable payloads should be included in the result
false
includeNonBillable=true
Name
Required
Description
Default
Authorization
Y
