Instance Organization Invites Actions
https://api.losant.com/instances/INSTANCE_ID
/orgs/ORG_ID
/invites
Below are the various requests that can be performed against the Instance Organization Invites resource, as well as the expected parameters and the potential responses.
Returns a collection of instance organization invites
GET https://api.losant.com/instances/INSTANCE_ID
/orgs/ORG_ID
/invites
all.Instance
, all.Instance.read
, all.User
, all.User.read
, instanceOrgInvites.*
, or instanceOrgInvites.get
INSTANCE_ID | ID associated with the instance | 575ec8687ae143cd83dc4a97 |
ORG_ID | ID associated with the organization | 575ec8687ae143cd83dc4a97 |
sortField | N | Field to sort the results by. Accepted values are: email, role, inviteDate | inviteDate | sortField=role |
sortDirection | N | Direction to sort the results by. Accepted values are: asc, desc | desc | sortDirection=asc |
filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: email, role | filterField=email | |
filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my * instance |
https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/invites
Code | Type | Description |
200 | Instance Organization Invitations | A collection of instance organization invitations |
404 | Error | Error if instance or organization was not found |
Invites a member to an instance organization
POST https://api.losant.com/instances/INSTANCE_ID
/orgs/ORG_ID
/invites
all.Instance
, all.User
, or instanceOrgInvites.post
The body of the request should be serialized JSON that validates against the Organization Invitation Post schema. For example, the following would be a valid body for this request:
"email": "invitedUser@example.com",
"role": "edit"
-d '{"email":"invitedUser@example.com","role":"edit"}' \
201 | Instance Organization Invitations | The new organization invite |
Schema for an collection of pending invitations to an Instance Organization
Instance Organization Invitations Schema
- ▶{} 8 keys
Instance Organization Invitations Example
- 8
- "role"
- "asc"
Schema for the body of a request to send an invitation
Organization Invitation Post Schema
- ▶[] 2 items
Organization Invitation Post Example
- "invitedUser@example.com"
- "edit"
