OPC UA: Browse Node
The OPC UA: Browse Node allows you to browse node folders on your OPC UA Server. This node is only available in Edge Workflows.
OPC UA Browse Node
Configuration for the OPC UA: Browse Node is broken up across several sections:
Connection Configuration​
OPC UA Browse Node Configuration
  • OPC UA URI Template (Required): A string template for the OPC UA server URI.
  • Username Template (Optional): A string template for login username.
  • Password Template (Optional): A string template for login password.
Security Settings​
You can optionally select a SSL/TLS Security Policy for the connection to the OPC UA server through the dropdown selector. Security Policy options include:
  • None
  • Basic-128
  • Basic-192
  • Basic-192 RSA-15
  • Basic-256
  • Basic-256 RSA-15
  • Basic-256 SHA-256
OPC UA Browse Node SSL/TLS Security
If a Security Policy is selected, you will have the option to select between "Sign" or "Sign and Encrypt" security modes. You'll then be required to provide a valid SSL/TLS client certificate and private key.
Browse Instructions​
OPC UA Browse Node Browse Instructions
Browse Instructions can be specified in one of two ways:
  • Template Strings: For the Browse Instruction, fill out the following input configuration fields, all of which can utilize templates:
    • Namespace Index Template (ns=) (Optional): A string template or positive integer.
    • Identifier or Browse Name Template (Optional): A string template or string for the node identifier or browse name. If the Namespace is left blank and this is a valid node browse name, the path will be resolved. If an identifier, the string should begin with one of the following types:
      • i=: for unsigned integer (UINT).
      • s=: for string.
      • g=: for global unique identifier (GUID).
      • b=: for byte string.
  • Payload Path: Enter a payload path that resolves to an array of Browse Instructions to be run on this node. The following are the object properties for successful attempts:
    Note: For Edge Workflows, this option is only available in GEA version 1.18.0 or higher.
    • nameSpace: (Optional) A string or positive integer.
    • identifier: (Optional) A string for the node identifier or browse name. If the nameSpace is left blank and this is a valid node browse name, the path will be resolved. If an identifier, the string should begin with one of the following types:
      • s=: for string.
The following is an example of an object that you could pass in:
"nameSpace": 3,
"identifier": "g=d6fe7561-65c5-4237-b31a-49b88a055d4c"
If the Namespace and Identifier are left blank or are not included in the Payload Path object the Browse Instructions will default to the "root folder".
Destination Path​
OPC UA Browse Node Result
The results of the browse instruction will be placed in an object with the name of the folder at the Destination Path (a payload path).
Result​
The following is an example of a successful browse of the "root folder", where the Destination Path is OPCUA_PLC:
"OPCUA_PLC": {
"RootFolder": [
"browseName": "Objects",
"displayName": "locale=null text=Objects",
"nodeId": "ns=0;i=85",
"namespace": 0,
"identifier": 85,
"identifierType": "Numeric",
"namespaceUri": "http://opcfoundation.org/UA/",
"isForward": true,
"nodeClass": "Object (1)"
The following is an example of a failure to browse, and the destination path is OPCUA_PLC:
"OPCUA_PLC": {
"errors": [
"type": "OPC-UA_BROWSE_ERROR",
