CSV: Encode Node
The CSV: Encode Node allows a workflow to encode an object array on the payload into a CSV string.
CSV: Encode Node
There are four main parts to the configuration of this node...
Input Path​
This required field specifies the payload path where the object array to be encoded is located.
CSV: Encode Node Input
CSV Headers​
There are three different ways to control the headers of the encoded CSV string - "Object Keys", "Individual Fields", and "Payload Path". The last two settings allow you to customize what headers will appear in the output CSV string, while the first setting is a simpler default.
CSV: Encode Node Headers
  • Object Keys: The default option. The CSV: Encode Node will read all the keys of the first given object and include all of them as headers for the encoded CSV string.
  • Individual Fields: Provide up to 10 string templates that will each be included as a header. Any object keys not included here will be excluded from the output.
  • Payload Path: Specify a payload path that contains an array of headers to include. Any object keys not included in the array will be excluded from the output.
Configuration​
CSV: Encode Node Config
This section contains four fields that specify the format for the encoded CSV string:
  • Character to Separate Rows of Data: (Optional) This is the character used to separate rows of data. Default \n.
  • Template for Delimiter: (Optional) A string template to override the delimiter. This character is used to separate columns of data. Must be a single character. Leave blank to default to comma (,).
  • Template for Quote Character: (Optional) A string template to override the quote character. Must be a single character. Leave blank to default to double-quote (").
  • Template for Escape Character: (Optional) A string template to override the escape character. Must be a single character. Leave blank to default to double-quote (").
Result Path​
This required field specifies the payload path where the encoded CSV string will be placed.
CSV: Encode Node Result
Node Example​
In this particular instance, the workflow will encode the object array at the data.in path and place the resulting CSV string at data.csvString.
So, for the following input payload...
"in": [
"Drink": "Soda",
"Food": "Burger"
"Drink": "Water",
"Food": "Taco"
The CSV: Encode Node would give the following output payload:
"csvString": "Food,Drink\nBurger,Soda\nTaco,Water\n",
"in": [
"Drink": "Soda",
"Food": "Burger"
"Drink": "Water",
"Food": "Taco"
"type": "InvalidType",
"message": "Type of input row is invalid (expected Array or Object but got String)"
Templates and paths which evaluate to invalid input will still error the workflow like so:
CSV: Encode Node Error
