Application Dashboard Actions
https://api.losant.com/applications/APPLICATION_ID/dashboards/DASHBOARD_ID
Below are the various requests that can be performed against the Application Dashboard resource, as well as the expected parameters and the potential responses.
Delete
Deletes a dashboard
DELETE https://api.losant.com/applications/APPLICATION_ID/dashboards/DASHBOARD_ID
all.Application, all.Organization, all.User, applicationDashboard.*, or applicationDashboard.delete.
| DASHBOARD_ID | ID of the associated dashboard | 575ece2b7ae143cd83dc4a9b |
| APPLICATION_ID | ID of the associated application | 575ec8687ae143cd83dc4a97 |
| 200 | Success | If dashboard was successfully deleted |
| 404 | Error | Error if dashboard was not found |
Retrieves information on a dashboard
GET https://api.losant.com/applications/APPLICATION_ID/dashboards/DASHBOARD_ID
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, applicationDashboard.*, or applicationDashboard.get.
| 200 | Dashboard | Dashboard information |
Patch
Updates information about a dashboard
PATCH https://api.losant.com/applications/APPLICATION_ID/dashboards/DASHBOARD_ID
all.Application, all.Organization, all.User, applicationDashboard.*, or applicationDashboard.patch.
The body of the request should be serialized JSON that validates against the Dashboard Patch schema. For example, the following would be a valid body for this request:
"name": "My Updated Dashboard",
"description": "Description of my updated dashboard",
"refreshRate": 300,
"public": true
-d '{"name":"My Updated Dashboard","description":"Description of my updated dashboard","refreshRate":300,"public":true}' \
| 200 | Dashboard | Update dashboard information |
Send Report
Sends a snapshot of a dashboard
POST https://api.losant.com/applications/APPLICATION_ID/dashboards/DASHBOARD_ID
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, applicationDashboard.*, or applicationDashboard.sendReport.
The body of the request should be serialized JSON that validates against the Dashboard Send Report schema. For example, the following would be a valid body for this request:
"toEmail": [
"email@example.com"
"subject": "Dashboard Report",
"message": "Lookit",
"time": 1551887386704,
"theme": "dark",
"timezone": "America/New_York",
"locale": "en-us"
-d '{"toEmail":["email@example.com"],"subject":"Dashboard Report","message":"Lookit","time":1551887386704,"theme":"dark","timezone":"America/New_York","locale":"en-us"}' \
| 202 | Job Enqueued API Result | If dashboard report was enqueued to be sent |
Dashboard
Schema for a single Dashboard
Dashboard Schema
- ▶{} 25 keys
Dashboard Example
- ▶{} 20 keys
- "575ece2b7ae143cd83dc4a9b"
- "Example Org"
- "#284fff"
- "organization"
- "58238ff2fe7b4b01009a0554"
- "My Dashboard"
- "The best dashboard description"
- 60
- "light"
- [] 0 items
- 600000
- 6000
- "admin"
- ▶[] 5 items
Dashboard Patch
Schema for the body of a Dashboard modification request
Dashboard Patch Schema
- ▶{} 11 keys
Dashboard Patch Example
- "My Updated Dashboard"
- "Description of my updated dashboard"
- 300
Schema for the body of a Dashboard report request
Dashboard Send Report Schema
- ▶{} 10 keys
- ▶[] 2 items
Dashboard Send Report Example
- ▶{} 7 keys
- "Dashboard Report"
- "Lookit"
- 1551887386704
- "dark"
- "America/New_York"
- "en-us"
Job Enqueued API Result Schema
Job Enqueued API Result Example
- "clnHvJbyVkOWAZwYAwLP4"
Success
Success Schema
Success Example
