Application Key Actions
https://api.losant.com/applications/APPLICATION_ID/keys/APPLICATION_KEY_ID
Below are the various requests that can be performed against the Application Key resource, as well as the expected parameters and the potential responses.
Delete
Deletes an applicationKey
DELETE https://api.losant.com/applications/APPLICATION_ID/keys/APPLICATION_KEY_ID
all.Application, all.Organization, all.User, applicationKey.*, or applicationKey.delete.
| APPLICATION_KEY_ID | ID associated with the applicationKey | 575ec76c7ae143cd83dc4a96 |
| 200 | Success | If applicationKey was successfully deleted |
| 404 | Error | Error if applicationKey was not found |
Retrieves information on an applicationKey
GET https://api.losant.com/applications/APPLICATION_ID/keys/APPLICATION_KEY_ID
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, applicationKey.*, or applicationKey.get.
| 200 | Application Key | applicationKey information |
Patch
Updates information about an applicationKey
PATCH https://api.losant.com/applications/APPLICATION_ID/keys/APPLICATION_KEY_ID
all.Application, all.Organization, all.User, applicationKey.*, or applicationKey.patch.
The body of the request should be serialized JSON that validates against the Application Key Patch schema. For example, the following would be a valid body for this request:
"status": "active",
"description": "An example updated key description"
-d '{"status":"active","description":"An example updated key description"}' \
| 200 | Application Key | Updated applicationKey information |
Application Key
Schema for a single Application Key
Application Key Schema
- ▶{} 13 keys
Application Key Example
- ▶{} 11 keys
- "575ec76c7ae143cd83dc4a96"
- "this_would_be_the_key"
- "active"
- "An example key description"
- "all"
- [] 0 items
- [] 0 items
Schema for the body of an Application Key modification request
Application Key Patch Schema
Application Key Patch Example
- "active"
- "An example updated key description"
Success
Success Schema
Success Example
