Data Table Row Actions
https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows/ROW_ID
Below are the various requests that can be performed against the Data Table Row resource, as well as the expected parameters and the potential responses.
Delete
Deletes a data table row
DELETE https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows/ROW_ID
all.Application, all.Organization, all.User, dataTableRow.*, or dataTableRow.delete.
| DATA_TABLE_ID | ID associated with the data table | 575ed78e7ae143cd83dc4aab |
| ROW_ID | ID associated with the data table row | 596f832b128eda5cfe765443 |
| 200 | Success | If data table row was successfully deleted |
| 404 | Error | Error if data table row was not found |
Retrieves the data table row
GET https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows/ROW_ID
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, dataTableRow.*, or dataTableRow.get.
| 200 | Data Table Row | Data table row information |
Patch
Updates the data table row
PATCH https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows/ROW_ID
all.Application, all.Organization, all.User, dataTableRow.*, or dataTableRow.patch.
The body of the request should be serialized JSON that validates against the Data Table Row Insert Update schema. For example, the following would be a valid body for this request:
"myColumn1": "myValue"
-d '{"myColumn1":"myValue"}' \
| 200 | Data Table Row | Updated data table row information |
Data Table Row
Schema for a single Data Table Row
Data Table Row Schema
Data Table Row Example
- "596fbb703fc088453872e609"
- "myValue"
- 5
Schema for inserting or updating a data table row
Data Table Row Insert Update Schema
Data Table Row Insert Update Example
- "myValue"
Success
Success Schema
Success Example
