Data Tables Actions
https://api.losant.com/applications/APPLICATION_ID/data-tables
Below are the various requests that can be performed against the Data Tables resource, as well as the expected parameters and the potential responses.
Returns the data tables for an application
GET https://api.losant.com/applications/APPLICATION_ID/data-tables
all.Application, all.Application.cli, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.cli, all.User.read, dataTables.*, or dataTables.get.
| sortField | N | Field to sort the results by. Accepted values are: name, id, creationDate, lastUpdated | name | sortField=name |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: name | filterField=name | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my*table |
| 200 | Data Tables | Collection of data tables |
Create a new data table for an application
POST https://api.losant.com/applications/APPLICATION_ID/data-tables
all.Application, all.Organization, all.User, dataTables.*, or dataTables.post.
The body of the request should be serialized JSON that validates against the Data Table Post schema. For example, the following would be a valid body for this request:
"name": "My Data Table",
"columns": [
"name": "myColumn1",
"dataType": "string",
"constraint": "unique"
"name": "myColumn2",
"dataType": "number",
"constraint": "optional"
-d '{"name":"My Data Table","columns":[{"name":"myColumn1","dataType":"string","constraint":"unique"},{"name":"myColumn2","dataType":"number","constraint":"optional"}]}' \
| 201 | Data Table | Successfully created data table |
Data Table
Schema for a single Data Table
Data Table Schema
- ▶{} 8 keys
Data Table Example
- ▶{} 7 keys
- "596e6ce831761df4231708f1"
- "My Data Table"
- ▶[] 2 items
Data Table Post
Schema for the body of a Data Table creation request
Data Table Post Schema
Data Table Post Example
- "My Data Table"
- ▶[] 2 items
Data Tables
Schema for a collection of Data Tables
Data Tables Schema
- ▶{} 10 keys
Data Tables Example
- ▶{} 8 keys
- 1
- 4
- 1
- 0
- "name"
- "asc"
