Device Recipe Actions
https://api.losant.com/applications/APPLICATION_ID/device-recipes/DEVICE_RECIPE_ID
Below are the various requests that can be performed against the Device Recipe resource, as well as the expected parameters and the potential responses.
Bulk Create
Bulk creates devices using this recipe from a CSV
POST https://api.losant.com/applications/APPLICATION_ID/device-recipes/DEVICE_RECIPE_ID/bulkCreate
all.Application, all.Organization, all.User, deviceRecipe.*, or deviceRecipe.bulkCreate.
| DEVICE_RECIPE_ID | ID associated with the device recipe | 575ecec57ae143cd83dc4a9f |
The body of the request should be serialized JSON that validates against the Device Recipe Bulk Create Post schema. For example, the following would be a valid body for this request:
"nameColumn": "myNameColumn",
"descriptionColumn": "column2",
"csv": "a,comma,separated,string,of,input,data"
-d '{"nameColumn":"myNameColumn","descriptionColumn":"column2","csv":"a,comma,separated,string,of,input,data"}' \
| 201 | Device Recipe Bulk Create | If devices were successfully created |
| 202 | Job Enqueued API Result | If devices were enqueued to be created |
| 404 | Error | Error if device recipe was not found |
Delete
Deletes a device recipe
DELETE https://api.losant.com/applications/APPLICATION_ID/device-recipes/DEVICE_RECIPE_ID
all.Application, all.Organization, all.User, deviceRecipe.*, or deviceRecipe.delete.
| 200 | Success | If device recipe was successfully deleted |
Retrieves information on a device recipe
GET https://api.losant.com/applications/APPLICATION_ID/device-recipes/DEVICE_RECIPE_ID
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, deviceRecipe.*, or deviceRecipe.get.
| tagsAsObject | N | Return tags as an object map instead of an array | tagsAsObject=true | |
| attributesAsObject | N | Return attributes as an object map instead of an array | attributesAsObject=true |
| 200 | Device Recipe | Device recipe information |
Patch
Updates information about a device recipe
PATCH https://api.losant.com/applications/APPLICATION_ID/device-recipes/DEVICE_RECIPE_ID
all.Application, all.Organization, all.User, deviceRecipe.*, or deviceRecipe.patch.
| tagsAsObject | N | Return tags as an object map instead of an array | tagsAsObject=false | |
| attributesAsObject | N | Return attributes as an object map instead of an array | attributesAsObject=false |
The body of the request should be serialized JSON that validates against the Device Recipe Patch schema. For example, the following would be a valid body for this request:
"name": "My Updated Device Recipe",
"deviceName": "Future device name",
"description": "Description of my updated device recipe",
"deviceDescription": "Future device description",
"tags": [
"key": "TagKey",
"value": "TagValue"
"attributes": [
"name": "voltage",
"dataType": "number"
"deviceClass": "standalone"
-d '{"name":"My Updated Device Recipe","deviceName":"Future device name","description":"Description of my updated device recipe","deviceDescription":"Future device description","tags":[{"key":"TagKey","value":"TagValue"}],"attributes":[{"name":"voltage","dataType":"number"}],"deviceClass":"standalone"}' \
| 200 | Device Recipe | Updated device recipe information |
Device Recipe
Schema for a single Device Recipe
Device Recipe Schema
- ▶{} 16 keys
Device Recipe Example
- ▶{} 12 keys
- "575ecec57ae143cd83dc4a9f"
- "Actual recipe name"
- "Future device name"
- "My recipe description"
- "Future device description"
- "standalone"
Schema for the result of a bulk Device creation request
Device Recipe Bulk Create Schema
Device Recipe Bulk Create Example
- 10
- 0
- "a,comma,separated,string,of,results"
Schema for the body of a bulk Device creation request
Device Recipe Bulk Create Post Schema
- ▶{} 11 keys
Device Recipe Bulk Create Post Example
- "myNameColumn"
- "column2"
- "a,comma,separated,string,of,input,data"
Device Recipe Patch
Schema for the body of a Device Recipe modification request
Device Recipe Patch Schema
- ▶{} 11 keys
Device Recipe Patch Example
- ▶{} 7 keys
- "My Updated Device Recipe"
- "Description of my updated device recipe"
- "standalone"
Job Enqueued API Result Schema
Job Enqueued API Result Example
- "clnHvJbyVkOWAZwYAwLP4"
Success
Success Schema
Success Example
