Instance API Tokens Actions
https://api.losant.com/instances/INSTANCE_ID/tokens
Below are the various requests that can be performed against the Instance API Tokens resource, as well as the expected parameters and the potential responses.
Returns the API tokens for an instance
GET https://api.losant.com/instances/INSTANCE_ID/tokens
all.Instance, all.Instance.bounded, all.Instance.read, all.User, all.User.bounded, all.User.read, instanceApiTokens.*, or instanceApiTokens.get.
| INSTANCE_ID | ID associated with the instance | 575ec7417ae143cd83dc4a96 |
| sortField | N | Field to sort the results by. Accepted values are: name, status, id, creationDate, lastUpdated, expirationDate | name | sortField=name |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: name, status | filterField=key | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my*token |
| 200 | API Tokens | Collection of API tokens |
Create a new API token for an instance
POST https://api.losant.com/instances/INSTANCE_ID/tokens
all.Instance, all.User, instanceApiTokens.*, or instanceApiTokens.post.
The body of the request should be serialized JSON that validates against the API Token Post schema. For example, the following would be a valid body for this request:
"name": "My New API Token",
"expirationDate": "2017-06-13T04:00:00.000Z",
"scope": [
"all.Application"
"status": "active"
-d '{"name":"My New API Token","expirationDate":"2017-06-13T04:00:00.000Z","scope":["all.Application"],"status":"active"}' \
| 201 | API Token | The successfully created API token |
API Token
Schema for a single API Token
API Token Schema
- ▶{} 19 keys
API Token Example
- ▶{} 13 keys
- "575ec7417ae143cd83dc4a95"
- "575ed70c7ae143cd83dc4aa9"
- "user"
- "application"
- "My API Token"
- "2017-06-13T04:00:00.000Z"
- "active"
- "the_actual_token_string"
API Token Post
Schema for the body of an API Token creation request
API Token Post Schema
- ▶{} 7 keys
API Token Post Example
- "My New API Token"
- "active"
API Tokens
Schema for a collection of API Tokens
API Tokens Schema
- ▶{} 13 keys
API Tokens Example
- ▶{} 9 keys
- 1
- 4
- 1
- 0
- "name"
- "asc"
- "application"
