Instance Notification Rule Actions
https://api.losant.com/instances/INSTANCE_ID/notification-rules/NOTIFICATION_RULE_ID
Below are the various requests that can be performed against the Instance Notification Rule resource, as well as the expected parameters and the potential responses.
Delete​
Deletes a notification rule
Method And Url​
DELETE https://api.losant.com/instances/INSTANCE_ID/notification-rules/NOTIFICATION_RULE_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.bounded, all.User, all.User.bounded, instanceNotificationRule.*, or instanceNotificationRule.delete.
Request Path Components​
INSTANCE_IDID associated with the instance575ec7417ae143cd83dc4a96
NOTIFICATION_RULE_IDID associated with the notification rule575ec7417ae143cd83dc4a95
Request Headers​
Curl Example​
Successful Responses​
CodeTypeDescription
200SuccessIf notification rule was successfully deleted
Error Responses​
CodeTypeDescription
404ErrorError if notification rule was not found
Evaluate​
Queues the evaluation of a notification rule
Method And Url​
POST https://api.losant.com/instances/INSTANCE_ID/notification-rules/NOTIFICATION_RULE_ID/evaluate
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.bounded, all.User, all.User.bounded, instanceNotificationRule.*, or instanceNotificationRule.evaluate.
Request Headers​
Request Body​
The body of the request should be serialized JSON that validates against the Notification Rule Evaluation Options schema. For example, the following would be a valid body for this request:
"ignoreFrequencyCheck": true
Curl Example​
-d '{"ignoreFrequencyCheck":true}' \
CodeTypeDescription
202Job Enqueued API ResultIf the evaluation was successfully queued
Error Responses​
CodeTypeDescription
Get​
Retrieves information on a notification rule
Method And Url​
GET https://api.losant.com/instances/INSTANCE_ID/notification-rules/NOTIFICATION_RULE_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.bounded, all.Instance.read, all.User, all.User.bounded, all.User.read, instanceNotificationRule.*, or instanceNotificationRule.get.
Request Headers​
Curl Example​
CodeTypeDescription
200Notification RuleNotification rule information
Error Responses​
CodeTypeDescription
Logs​
Retrieves information on notification rule deliveries
Method And Url​
GET https://api.losant.com/instances/INSTANCE_ID/notification-rules/NOTIFICATION_RULE_ID/logs
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.bounded, all.User, all.User.bounded, instanceNotificationRule.*, or instanceNotificationRule.logs.
Request Query Parameters​
limitNMax log entries to return (ordered by time descending)1limit=10
sinceNLook for log entries since this time (ms since epoch)since=1465790400000
Request Headers​
Curl Example​
CodeTypeDescription
200Notification Rule Delivery LogsNotification delivery information
Error Responses​
CodeTypeDescription
Patch​
Updates information about a notification rule
Method And Url​
PATCH https://api.losant.com/instances/INSTANCE_ID/notification-rules/NOTIFICATION_RULE_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.bounded, all.User, all.User.bounded, instanceNotificationRule.*, or instanceNotificationRule.patch.
Request Headers​
Request Body​
The body of the request should be serialized JSON that validates against the Notification Rule Patch schema. For example, the following would be a valid body for this request:
"name": "My Updated Notification Rule",
"enabled": false
Curl Example​
-d '{"name":"My Updated Notification Rule","enabled":false}' \
CodeTypeDescription
200Notification RuleUpdated notification rule information
Error Responses​
CodeTypeDescription
Schemas​
Error​
Error Schema​
    {} 3 keys
    • "object"
      {} 3 keys
        {} 1 key
          {} 1 key
            {} 2 keys
        Error Example​
          {} 2 keys
          • "NotFound"
          • "Application was not found"
        Job Enqueued API Result​
        Job Enqueued API Result Schema​
          {} 3 keys
          • "object"
            {} 3 keys
              {} 2 keys
                {} 2 keys
                  {} 2 keys
              Job Enqueued API Result Example​
                {} 3 keys
                • true
                • "clnHvJbyVkOWAZwYAwLP4"
                • true
              Notification Rule​
              Schema for a single notification rule
              Notification Rule Schema​
                {} 3 keys
                • "object"
                  {} 19 keys
                    {} 2 keys
                      {} 2 keys
                        {} 2 keys
                          {} 2 keys
                            {} 2 keys
                              {} 2 keys
                                {} 2 keys
                                  {} 2 keys
                                    {} 2 keys
                                      {} 2 keys
                                        {} 2 keys
                                          {} 2 keys
                                            {} 2 keys
                                              {} 3 keys
                                                {} 2 keys
                                                  {} 1 key
                                                    {} 3 keys
                                                      {} 4 keys
                                                        {} 4 keys
                                                    Notification Rule Example​
                                                      {} 16 keys
                                                      • "585ec7417ae143cd83dc4a95"
                                                      • "60106426dc03c6aad06560ba"
                                                      • "instance"
                                                      • "2016-06-13T04:00:00.000Z"
                                                      • "575ed70c7ae143cd83dc4aa9"
                                                      • "user"
                                                      • "user"
                                                      • "organization"
                                                      • "My Notification Rule"
                                                      • true
                                                        {} 5 keys
                                                          {} 4 keys
                                                        Notification Rule Delivery Logs​
                                                        Schema for a set of Notification Rule delivery logs
                                                        Notification Rule Delivery Logs Schema​
                                                          {} 3 keys
                                                          • "array"
                                                            {} 2 keys
                                                          Notification Rule Delivery Logs Example​
                                                            [] 1 item
                                                              {} 13 keys
                                                            Notification Rule Evaluation Options​
                                                            Schema for evaluation options for a notification rule
                                                            Notification Rule Evaluation Options Schema​
                                                              {} 4 keys
                                                              • "object"
        {} 1 key
        {} 1 key
        • false
                                                              Notification Rule Evaluation Options Example​
        {} 1 key
        • true
                                                              Notification Rule Patch​
                                                              Schema for the body of a notification rule modification request
                                                              Notification Rule Patch Schema​
        {} 4 keys
        • "object"
        {} 7 keys
        {} 2 keys
        {} 3 keys
        {} 2 keys
        {} 1 key
        {} 1 key
        {} 1 key
        {} 4 keys
        • false
        Notification Rule Patch Example​
        {} 2 keys
        • "My Updated Notification Rule"
        • false
        Success​
        Success Schema​
        {} 3 keys
        • "object"
        {} 1 key
        {} 2 keys
        Success Example​
        {} 1 key
        • true
