Instance Organization Invite Actions
https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/invites/INVITE_ID
Below are the various requests that can be performed against the Instance Organization Invite resource, as well as the expected parameters and the potential responses.
Delete​
Revokes an instance org invitation
Method And Url​
DELETE https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/invites/INVITE_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.User, instanceOrgInvite.*, or instanceOrgInvite.delete.
Request Path Components​
INSTANCE_IDID associated with the instance575ec8687ae143cd83dc4a95
ORG_IDID associated with the organization575ec8687ae143cd83dc4a97
INVITE_IDID associated with the organization invite575ec8687ae143cd83dc4a94
Request Headers​
Curl Example​
Successful Responses​
CodeTypeDescription
200SuccessIf an invite was successfully deleted
Error Responses​
CodeTypeDescription
404ErrorError if instance, organization or invite was not found
Get​
Returns an organization invite
Method And Url​
GET https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/invites/INVITE_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.bounded, all.Instance.read, all.User, all.User.bounded, all.User.read, instanceOrgInvite.*, or instanceOrgInvite.get.
Request Headers​
Curl Example​
CodeTypeDescription
200Instance Organization InvitationA single organization invite
Error Responses​
CodeTypeDescription
404ErrorError if instance, organization, or invite was not found
Resend Invite​
Resend an organization invite with modified role info
Method And Url​
POST https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/invites/INVITE_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.User, instanceOrgInvite.*, or instanceOrgInvite.resendInvite.
Request Headers​
Request Body​
The body of the request should be serialized JSON that validates against the Organization Role Info schema. For example, the following would be a valid body for this request:
"role": "view"
Curl Example​
-d '{"role":"view"}' \
CodeTypeDescription
201Instance Organization InvitationThe new org invite
Error Responses​
CodeTypeDescription
Schemas​
Error​
Error Schema​
    {} 3 keys
    • "object"
      {} 3 keys
        {} 1 key
          {} 1 key
            {} 2 keys
        Error Example​
          {} 2 keys
          • "NotFound"
          • "Application was not found"
        Instance Organization Invitation​
        Schema for a pending invitation to an Organization within an instance
        Instance Organization Invitation Schema​
          {} 3 keys
          • "object"
            {} 12 keys
              {} 2 keys
                {} 3 keys
                  {} 2 keys
                    {} 3 keys
                      {} 3 keys
                        {} 2 keys
                          {} 1 key
                            {} 1 key
                              {} 1 key
                                {} 2 keys
                                  {} 2 keys
                                    {} 2 keys
                                Instance Organization Invitation Example​
                                  {} 12 keys
                                  • "575ec8687ae143cd83dc4a97"
                                  • "test@example.com"
                                  • "admin"
                                  • [] 0 items
                                    • [] 0 items
                                      • "2016-06-13T04:00:00.000Z"
                                      • 604800000
                                      • false
                                      • false
                                      • "575ec8687ae143cd83dc4a98"
                                      • "575ec8687ae143cd83dc4a99"
                                    Organization Role Info​
                                    Schema for an Organization member's role info
                                    Organization Role Info Schema​
                                      {} 4 keys
                                      • "object"
                                        {} 3 keys
                                          {} 2 keys
                                            {} 3 keys
                                              {} 3 keys
                                            • false
                                          Organization Role Info Example​
                                            {} 1 key
                                            • "view"
                                          Success​
                                          Success Schema​
                                            {} 3 keys
                                            • "object"
                                              {} 1 key
                                                {} 2 keys
                                            Success Example​
                                              {} 1 key
                                              • true
