Organization Invites Actions
https://api.losant.com/invites
Below are the various requests that can be performed against the Organization Invites resource, as well as the expected parameters and the potential responses.
Gets information about an invite
GET https://api.losant.com/invites
No authentication is required for this endpoint.
| token | Y | The token associated with the invite | token=aTokenString | |
| Y | The email associated with the invite | email=example@example.com |
    https://api.losant.com/invites?token=aTokenString&email=example%40example.com
| 200 | Organization Invitation Information | Information about invite |
| 404 | Error | Error if invite not found |
| 410 | Error | Error if invite has expired |
Accepts/Rejects an invite
POST https://api.losant.com/invites
The body of the request should be serialized JSON that validates against the Organization Invitation Action schema. For example, the following would be a valid body for this request:
  "email": "invitedUser@example.com",
  "token": "the_invitation_token",
  "accept": true
    -d '{"email":"invitedUser@example.com","token":"the_invitation_token","accept":true}' \
| 200 | Organization Invitation Result | Acceptance/Rejection of invite |
Schema for the body of a request to accept or reject an invitation
Organization Invitation Action Schema
 - ▶[] 3 items
Organization Invitation Action Example
- "invitedUser@example.com"
 - "the_invitation_token"
Schema for information about an invitation
Organization Invitation Information Schema
 - ▶{} 6 keys
Organization Invitation Information Example
- ▶{} 6 keys
- "My Organization"
 - "edit"
 - "2016-05-13T04:00:00.000Z"
 - 4233600000
Schema for the result of accepting/rejecting an invitation
Organization Invitation Result Schema
Organization Invitation Result Example
 - "575ed6e87ae143cd83dc4aa8"
