User Oauth Token Actions
https://api.losant.com/me/oauth-tokens/OAUTH_TOKEN_ID
Below are the various requests that can be performed against the User Oauth Token resource, as well as the expected parameters and the potential responses.
Delete​
Deletes an OAuth Token
Method And Url​
DELETE https://api.losant.com/me/oauth-tokens/OAUTH_TOKEN_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.User, only.User, userOauthToken.*, or userOauthToken.delete.
Request Path Components​
OAUTH_TOKEN_IDID associated with the OAuth token575ec7417ae143cd83dc4a95
Request Headers​
Curl Example​
Successful Responses​
CodeTypeDescription
200SuccessIf OAuth token was successfully deleted
Error Responses​
CodeTypeDescription
404ErrorError if OAuth token was not found
Get​
Retrieves information on an OAuth token
Method And Url​
GET https://api.losant.com/me/oauth-tokens/OAUTH_TOKEN_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.User, all.User.bounded, all.User.read, only.User, only.User.bounded, only.User.read, userOauthToken.*, or userOauthToken.get.
Request Headers​
Curl Example​
CodeTypeDescription
200User OAuth TokenOAuth token information
Error Responses​
CodeTypeDescription
Patch​
Updates information about an OAuth token
Method And Url​
PATCH https://api.losant.com/me/oauth-tokens/OAUTH_TOKEN_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.User, only.User, userOauthToken.*, or userOauthToken.patch.
Request Headers​
Request Body​
The body of the request should be serialized JSON that validates against the User OAuth Token Patch schema. For example, the following would be a valid body for this request:
"name": "Updated OAuth App Name",
"description": "Updated description",
"defaultRole": "edit",
"status": "inactive"
Curl Example​
-d '{"name":"Updated OAuth App Name","description":"Updated description","defaultRole":"edit","status":"inactive"}' \
CodeTypeDescription
200User OAuth TokenUpdated OAuth token information
Error Responses​
CodeTypeDescription
Schemas​
Error​
Error Schema​
    {} 3 keys
    • "object"
      {} 3 keys
        {} 1 key
          {} 1 key
            {} 2 keys
        Error Example​
          {} 2 keys
          • "NotFound"
          • "Application was not found"
        Success​
        Success Schema​
          {} 3 keys
          • "object"
            {} 1 key
              {} 2 keys
          Success Example​
            {} 1 key
            • true
          User OAuth Token​
          Schema for a single OAuth Token
          User OAuth Token Schema​
            {} 3 keys
            • "object"
              {} 12 keys
                {} 2 keys
                  {} 2 keys
                    {} 3 keys
                      {} 2 keys
                        {} 2 keys
                          {} 2 keys
                            {} 2 keys
                              {} 2 keys
                                {} 3 keys
                                  {} 4 keys
                                    {} 2 keys
                                      {} 2 keys
                                  User OAuth Token Example​
                                    {} 11 keys
                                    • "575ec7417ae143cd83dc4a95"
                                    • "My OAuth App"
                                    • "OAuth application for automation"
                                    • "2016-06-13T04:00:00.000Z"
                                      [] 2 items
                                      • "view"
                                      • [] 0 items
                                        • "active"
                                          {} 6 keys
                                        User OAuth Token Patch​
                                        Schema for the body of an OAuth Token modification request
                                        User OAuth Token Patch Schema​
                                          {} 4 keys
                                          • "object"
                                            {} 5 keys
                                              {} 3 keys
                                                {} 2 keys
                                                  {} 2 keys
                                                    {} 3 keys
                                                      {} 2 keys
                                                    • false
                                                  User OAuth Token Patch Example​
                                                    {} 4 keys
                                                    • "Updated OAuth App Name"
                                                    • "Updated description"
                                                    • "edit"
                                                    • "inactive"
