User Oauth Tokens Actions
https://api.losant.com/me/oauth-tokens
Below are the various requests that can be performed against the User Oauth Tokens resource, as well as the expected parameters and the potential responses.
Get​
Returns the OAuth tokens for a user
Method And Url​
GET https://api.losant.com/me/oauth-tokens
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.User, all.User.bounded, all.User.read, only.User, only.User.bounded, only.User.read, userOauthTokens.*, or userOauthTokens.get.
Request Query Parameters​
sortFieldNField to sort the results by. Accepted values are: name, status, id, creationDate, lastUpdatednamesortField=name
filterFieldNField to filter the results by. Blank or not provided means no filtering. Accepted values are: namefilterField=name
filterNFilter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering.filter=my*app
Request Headers​
Curl Example​
Successful Responses​
CodeTypeDescription
200User OAuth TokensCollection of OAuth tokens
Error Responses​
CodeTypeDescription
Post​
Create a new OAuth token for a user
Method And Url​
POST https://api.losant.com/me/oauth-tokens
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.User, only.User, userOauthTokens.*, or userOauthTokens.post.
Request Headers​
Request Body​
The body of the request should be serialized JSON that validates against the User OAuth Token Post schema. For example, the following would be a valid body for this request:
"name": "My OAuth App",
"description": "OAuth application for automation",
"scope": [
"only.User.read",
"all.Application.read"
"defaultRole": "view",
"oauth": {
"client_id": "575ec8687ae143cd83dc4a97",
"redirect_uri": "https://example.com/callback",
"code_challenge": "E9Melhoa2OwvFrEMTJguCHaoeK1t8URWbuGJSstw-cM",
"code_challenge_method": "S256"
Curl Example​
-d '{"name":"My OAuth App","description":"OAuth application for automation","scope":["only.User.read","all.Application.read"],"defaultRole":"view","oauth":{"client_id":"575ec8687ae143cd83dc4a97","redirect_uri":"https://example.com/callback","code_challenge":"E9Melhoa2OwvFrEMTJguCHaoeK1t8URWbuGJSstw-cM","code_challenge_method":"S256"}}' \
CodeTypeDescription
201User OAuth TokenThe successfully created OAuth token
Error Responses​
CodeTypeDescription
Schemas​
Error​
Error Schema​
    {} 3 keys
    • "object"
      {} 3 keys
        {} 1 key
          {} 1 key
            {} 2 keys
        Error Example​
          {} 2 keys
          • "NotFound"
          • "Application was not found"
        User OAuth Token​
        Schema for a single OAuth Token
        User OAuth Token Schema​
          {} 3 keys
          • "object"
            {} 12 keys
              {} 2 keys
                {} 2 keys
                  {} 3 keys
                    {} 2 keys
                      {} 2 keys
                        {} 2 keys
                          {} 2 keys
                            {} 2 keys
                              {} 3 keys
                                {} 4 keys
                                  {} 2 keys
                                    {} 2 keys
                                User OAuth Token Example​
                                  {} 11 keys
                                  • "575ec7417ae143cd83dc4a95"
                                  • "My OAuth App"
                                  • "OAuth application for automation"
                                  • "2016-06-13T04:00:00.000Z"
                                    [] 2 items
                                    • "view"
                                    • [] 0 items
                                      • "active"
                                        {} 6 keys
                                      User OAuth Token Post​
                                      Schema for the body of an OAuth Token creation request
                                      User OAuth Token Post Schema​
                                        {} 5 keys
                                        • "object"
                                          {} 7 keys
                                            {} 3 keys
                                              {} 2 keys
                                                {} 2 keys
                                                  {} 4 keys
                                                    {} 2 keys
                                                      {} 3 keys
                                                        {} 4 keys
                                                      • false
                                                        [] 2 items
                                                      User OAuth Token Post Example​
                                                        {} 5 keys
                                                        • "My OAuth App"
                                                          [] 2 items
                                                          • "view"
                                                            {} 4 keys
                                                          User OAuth Tokens​
                                                          Schema for a collection of OAuth Tokens
                                                          User OAuth Tokens Schema​
                                                            {} 3 keys
                                                            • "object"
                                                              {} 9 keys
        {} 2 keys
        {} 1 key
        {} 1 key
        {} 1 key
        {} 1 key
        {} 1 key
        {} 1 key
        {} 1 key
        {} 2 keys
        User OAuth Tokens Example​
        {} 7 keys
        [] 1 item
        • 1
        • 1
        • 1000
        • 0
        • "name"
        • "asc"
