OTel Logs: Write Node
The OTel Logs: Write Node writes custom log records to an OpenTelemetry (OTel) collector running on the same host machine as the Gateway Edge Agent (or accessible over HTTP/HTTPS). This node is only available in Edge Workflows.
Configuration for the OTel Logs: Write Node is divided into four main sections: Connection, Resource Config, Logs, and Result.
Connection
Configure the network location and authentication details for reaching the OpenTelemetry collector over OTLP/HTTP:
- Configuration Type: Select how to supply the collector connection details:
- Individual Fields: (Default) Enter the connection, authorization, and SSL configuration directly on the node.
- Agent Config File: Pull the collector URL, authorization, and TLS configuration from the Edge Agent container's
[otlpCollector]configuration file block. When selected, the inline connection fields below are hidden, but any Resource Attributes defined on this node are still merged on top of the agent configuration.
When Individual Fields is selected, configure the following:
- Collector URL Template: (Required) A string template for the base URL of the OpenTelemetry collector:
- The URL can optionally include a custom port or a path prefix.
- Do not include an OTLP signal path (such as
/v1/metrics,/v1/logs, or/v1/traces), query strings, fragments, or embedded credentials. The node automatically appends/v1/logswhen transmitting data.
- Authorization Type: Select an authentication method to include with requests sent to the collector:
- None: (Default) No authorization headers are sent.
- Basic: Sends a Basic authorization header. Requires:
- Username Template: (Required) A string template resolving to the username.
- Password Template: (Optional) A string template resolving to the password.
- Bearer Token: Sends a
Bearertoken in the authorization header. Requires:- Bearer Token Template: (Required) A string template resolving to the token.
- Client Certificate: Authenticates using an mTLS client certificate and private key.
- Private Key Input Method: Choose between
Local File Path Template(a file path on the Edge Agent's file system) orDirect Input(paste the PEM-encoded private key or template). - Certificate Input Method: Choose between
Local File Path Template(a file path on the Edge Agent's file system) orDirect Input(paste the PEM-encoded certificate or template).
- SSL Verification Options:
- Use Default Certificate Authority: (Default) Verifies the collector's certificate against standard system CAs.
- Provide Custom Certificate Authority: Allows providing a custom CA certificate to verify self-signed or internal collector certificates. Select between
Local File Path TemplateorDirect Input. - Disable SSL Verification: Disables TLS verification for untrusted or self-signed server certificates. When enabled, any configured custom CA certificate is ignored.
Resource Config
Optionally define the instrumentation scope and resource attributes associated with the emitted logs.
- Scope Name Template: (Optional) A string template for the instrumentation scope name. Defaults to
gea-otel-writeif not provided. - Scope Name Version Template: (Optional) A string template for the scope version. Defaults to the current Gateway Edge Agent version if not provided.
- Resource Attributes Method: Choose how to define resource-level attributes (for example,
service.nameorhost.name):- Individual Fields: (Default) Define key-value pairs row-by-row. Both key and value support string templates. Integer, float, and boolean values are preserved as their respective OTLP types rather than exported as strings.
- JSON Template: Provide a JSON template that resolves to a flat JSON object of key-value pairs:
{"service.name": "edge-gateway-01","host.name": "{{agent.hostname}}","deployment.environment": "production"}
- Payload Path: Provide a payload path pointing to a flat object containing key-value pairs on the current payload.
Logs
Define one or more custom log records to write to the OpenTelemetry collector. First, choose a Logs Input Method:
Individual Fields
Define each log record individually. At least one log record is required:
Body Template: (Required) A string template resolving to the log message body (for example,
{{working.logEntry}}or a literal string message). -
Severity Template: (Required) A string template resolving to the log severity. You can select from the dropdown or enter a custom template. Defaults to
9 (INFO). Accepts standard OpenTelemetry values as either a numeric integer (1to24, or0for unspecified) or as a case-insensitive string matching any of the named levels:Named Level Numeric Value Dropdown Option TRACE1 1 (TRACE) DEBUG5 5 (DEBUG) INFO9 9 (INFO) (Default) WARN/WARNING13 13 (WARN/WARNING) ERROR17 17 (ERROR) FATAL21 21 (FATAL) Custom templates resolving to any integer between
1and24(such as intermediate sub-levels defined by the OpenTelemetry specification) or0(unspecified) are also supported. -
Event Name Template: (Optional) A string template resolving to the name of the event represented by this log record.
Observed Timestamp Template (ms): (Optional) A Unix timestamp in milliseconds, Unix timestamp in seconds, or ISO 8601 date string representing the time the event was observed. Defaults to the current workflow execution time if not set.
Timestamp Template (ms): (Optional) A Unix timestamp in milliseconds, Unix timestamp in seconds, or ISO 8601 date string representing the time the event occurred. Omitted from the log record if left blank.
Log Attributes Method: Define attributes specific to this log record:
- Individual Fields: (Default) Define key-value rows using string templates. Values render typed per OTLP attribute rules (booleans, integers, floats, or strings).
- JSON Template: A JSON template resolving to a flat JSON object of attribute keys and values:
{"sensor.id": "{{working.sensorId}}","location": "facility-a"}
- Payload Path: A payload path pointing to a flat object of attribute key-value pairs on the payload.
JSON Template
When selected, provide a JSON template resolving to an array of OpenTelemetry log record objects (or a single log record object) matching the OTLP specification:
"timeUnixNano": "{{working.timestampNanos}}",
"severityNumber": 17,
"severityText": "ERROR",
"body": { "stringValue": "Sensor read failed" },
"attributes": [
{ "key": "sensor.id", "value": { "stringValue": "temp-01" } }
"severityNumber": 9,
"body": { "stringValue": "Device state reported successfully" },
"attributes": []
Payload Path
When selected, provide a payload path pointing to an array of log record objects (or a single log record object) formatted according to the OTLP specification, as shown in the JSON Template example above.
Optionally, enter a payload path for where to store the result of the write operation.
The following is an example of a successful operation:
"success": true,
"logCount": 2
If the operation failed (for example, collector unreachable or non-200 HTTP response), the object placed at the path will contain an error:
"success": false,
"type": "OTEL_COLLECTOR_RESPONSE_ERROR",
"message": "HTTP 500: Internal Server Error"
Possible error type values include:
OTEL_COLLECTOR_RESPONSE_ERROR: The collector responded with a non-2xx status code.OTEL_COLLECTOR_REQUEST_ERROR: The collector was unreachable (for example, network failure, connection refused).NodeTimeout: The request timed out before the collector responded.Validation: An invalid host, URL, or certificate file was encountered during the request.
If the collector accepted the request but partially rejected log records (or reported warnings), rejectedLogRecords and rejectedMessage will be included:
"success": true,
"logCount": 2,
"rejectedLogRecords": 1,
"rejectedMessage": "body too large"
