Email Node
We intend for Losant Developers to use this node for testing and/or proof of concept applications. For production applications, we recommend the SendGrid Node or the Mailgun Node. Using these nodes allows for:
- No rate limits
- History of messages sent
- Custom "From" addresses
- And more
The Email Node allows a workflow to send emails using Losant provided email delivery.
The Email Node has three main configuration sections:
Recipient Addresses
The Email Node supports up to 5 "To" addresses for the email. These address fields support string templates to use emails on the current workflow payload.
Note: The "From Address" cannot be changed when using the Email Node. It defaults to <theWorkflowID>@workflows.losant.com.
Message Contents
Next, the contents of the email can be configured. There are two items to configure here, and both are templatable.
- Email Subject: (Required) The subject of the email.
- Email Body: (Required) The email message to send.
You may optionally store an indication of the success or failure of the email operation at a path on the payload.
In the example above, the subject is set to Power Consumption Warning and the body is set to Power level exceeded error threshold at {{data.power}}!.
If the result path has been configured, the success or failure of the operation will be placed at that path like so:
"emailResult": {
"message": "success"
"emailResult": {
"type": "LOSANT_EMAIL_ERROR",
"message": "Losant email send throttled.",
Node Throttling and Limits
For Sandbox accounts, this node is rate limited to 1 email every 5 minutes, with a burst of up to 5. For Organizations, the limit is 1 email per minute, with a burst of up to 10.
If more frequent emails or more advanced recipient configuration is required, please use the SendGrid Node or the Mailgun Node.
Related Notes
