Application Dashboards Actions
/dashboards
Below are the various requests that can be performed against the Application Dashboards resource, as well as the expected parameters and the potential responses.
Returns all dashboards scoped to the given application.
/dashboards
all.Application
, all.Application.read
, all.Organization
, all.Organization.read
, all.User
, all.User.read
, applicationDashboards.*
, or applicationDashboards.get
sortField | N | Field to sort the results by. Accepted values are: name, id, creationDate, lastUpdated | name | sortField=name |
filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: name | filterField=name | |
filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my * dashboard |
https://api.losant.com/applications/APPLICATION_ID/dashboards
Code | Type | Description |
200 | Dashboards | Collection of dashboards |
Create a new dashboard
/dashboards
all.Application
, all.Organization
, all.User
, or applicationDashboards.post
The body of the request should be serialized JSON that validates against the Application Dashboard Post schema. For example, the following would be a valid body for this request:
"name": "My New Dashboard",
"public": false
-d '{"name":"My New Dashboard","public":false}' \
201 | Dashboard | Successfully created dashboard |
Schema for the body of an Application scoped Dashboard creation request
Application Dashboard Post Schema
- ▶{} 11 keys
Application Dashboard Post Example
- "My New Dashboard"
Dashboard
Schema for a single Dashboard
Dashboard Schema
- ▶{} 25 keys
Dashboard Example
- ▶{} 20 keys
- "575ece2b7ae143cd83dc4a9b"
- "Example Org"
- "#284fff"
- "organization"
- "58238ff2fe7b4b01009a0554"
- "My Dashboard"
- "The best dashboard description"
- 60
- "light"
- [] 0 items
- 600000
- 6000
- "admin"
- ▶[] 5 items
Dashboards
Schema for a collection of Dashboards
Dashboards Schema
- ▶{} 11 keys
Dashboards Example
- ▶{} 7 keys
- 1
- 5
- 1
- 0
- "name"
- "asc"
