Access Keys Actions
https://api.losant.com/applications/APPLICATION_ID/keys
Below are the various requests that can be performed against the Access Keys resource, as well as the expected parameters and the potential responses.
Returns the applicationKeys for an application
GET https://api.losant.com/applications/APPLICATION_ID/keys
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, applicationKeys.*, or applicationKeys.get.
sortFieldNField to sort the results by. Accepted values are: key, status, id, creationDate, lastUpdated, namecreationDatesortField=creationDate
sortDirectionNDirection to sort the results by. Accepted values are: asc, descdescsortDirection=asc
filterFieldNField to filter the results by. Blank or not provided means no filtering. Accepted values are: key, status, namefilterField=key
filterNFilter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering.filter=the*key
queryNApplication key filter JSON object which overrides the filterField and filter parameters. See Advanced Application Key Query for more details.query={"$nor":[{"id":"575ec8687ae143cd83dc4a97"},{"description":"my access key"},{"lastUpdated":{"$lt":1612189931000}}]}
CodeTypeDescription
200Application KeysCollection of applicationKeys
CodeTypeDescription
Create a new applicationKey for an application
POST https://api.losant.com/applications/APPLICATION_ID/keys
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, applicationKeys.*, or applicationKeys.post.
The body of the request should be serialized JSON that validates against the Application Key Post schema. For example, the following would be a valid body for this request:
"description": "An example new key description",
"filterType": "all",
"pubTopics": [],
"subTopics": []
-d '{"description":"An example new key description","filterType":"all","pubTopics":[],"subTopics":[]}' \
CodeTypeDescription
201Application Key Post ResponseSuccessfully created applicationKey
CodeTypeDescription
Schema for advanced application key queries
Advanced Application Key Query Schema
  • {} 3 keys
    • "object"
    • {} 17 keys
      • {} 3 keys
        • {} 3 keys
          • {} 3 keys
            • {} 1 key
              • {} 1 key
                • {} 1 key
                  • {} 1 key
                    • {} 1 key
                      • {} 1 key
                        • {} 1 key
                          • {} 1 key
                            • {} 1 key
                              • {} 1 key
                                • {} 1 key
                                  • {} 1 key
                                    • {} 1 key
                                      • {} 1 key
                                    Advanced Application Key Query Example
                                    • {} 1 key
                                      • [] 3 items
                                      Schema for the body of an Application Key creation request
                                      Application Key Post Schema
                                      • {} 4 keys
                                        • "object"
                                        • {} 9 keys
                                          • {} 3 keys
                                            • {} 3 keys
                                              • {} 3 keys
                                                • {} 2 keys
                                                  • {} 1 key
                                                    • {} 2 keys
                                                      • {} 2 keys
                                                        • {} 2 keys
                                                          • {} 3 keys
                                                          • false
                                                        Application Key Post Example
                                                        • {} 4 keys
                                                          • "An example new key description"
                                                          • "all"
                                                          • [] 0 items
                                                            • [] 0 items
                                                            Schema for a response of Application Key creation
                                                            Application Key Post Response Schema
                                                            • {} 3 keys
                                                              • "object"
                                                              • {} 21 keys
        • {} 2 keys
        • {} 2 keys
        • {} 2 keys
        • {} 2 keys
        • {} 2 keys
        • {} 2 keys
        • {} 2 keys
        • {} 2 keys
        • {} 2 keys
        • {} 1 key
        • {} 2 keys
        • {} 1 key
        • {} 3 keys
        • {} 3 keys
        • {} 3 keys
        • {} 2 keys
        • {} 1 key
        • {} 2 keys
        • {} 2 keys
        • {} 2 keys
        • {} 3 keys
        Application Key Post Response Example
        • {} 12 keys
        • "575ec76c7ae143cd83dc4a96"
        • "575ec8687ae143cd83dc4a97"
        • "2016-06-13T04:00:00.000Z"
        • "this_would_be_the_key"
        • "active"
        • "shhhSecret"
        • "An example key description"
        • "all"
        • [] 0 items
        • [] 0 items
        Application Keys
        Schema for a collection of Application Keys
        Application Keys Schema
        • {} 3 keys
        • "object"
        • {} 10 keys
        • {} 2 keys
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 2 keys
        • {} 2 keys
        Application Keys Example
        • {} 8 keys
        • [] 1 item
        • 1
        • 4
        • 1
        • 0
        • "key"
        • "asc"
        • {} 3 keys
        • "object"
        • {} 2 keys
        • {} 1 key
        • {} 1 key
        • {} 2 keys
        • "NotFound"
        • "Application was not found"
