Application Template Actions
https://api.losant.com/applicationTemplates/TEMPLATE_ID
Below are the various requests that can be performed against the Application Template resource, as well as the expected parameters and the potential responses.
Retrieves information on an application template
GET https://api.losant.com/applicationTemplates/TEMPLATE_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.User, all.User.read, applicationTemplate.*, or applicationTemplate.get.
TEMPLATE_IDID associated with the template575ed0de7ae143cd83dc4aa5
CodeTypeDescription
200Application TemplateApplication template information
CodeTypeDescription
404ErrorError if template was not found
Schema for a single Application Template
Application Template Schema
  • {} 3 keys
    • "object"
    • {} 15 keys
      • {} 2 keys
        • {} 2 keys
          • {} 2 keys
            • {} 2 keys
              • {} 3 keys
                • {} 2 keys
                  • {} 3 keys
                    • {} 3 keys
                      • {} 2 keys
                        • {} 1 key
                          • {} 2 keys
                            • {} 2 keys
                              • {} 2 keys
                                • {} 2 keys
                                  • {} 2 keys
                                Application Template Example
                                • {} 10 keys
                                  • "586e9d5151265cb9d72f6ec6"
                                  • "2020-01-13T04:00:00.000Z"
                                  • "smart environment"
                                  • "a smart env set up"
                                  • true
                                  • "Example Author"
                                  • "https://example.com/theAuther"
                                  • "https://example.com/theTemplate"
                                  • {} 18 keys
                                  • {} 3 keys
                                    • "object"
                                    • {} 2 keys
                                      • {} 1 key
                                        • {} 1 key
                                      • {} 2 keys
                                        • "NotFound"
                                        • "Application was not found"
