Audit Log Actions
https://api.losant.com/orgs/ORG_ID
/audit-logs/AUDIT_LOG_ID
Below are the various requests that can be performed against the Audit Log resource, as well as the expected parameters and the potential responses.
Retrieves information on an audit log
GET https://api.losant.com/orgs/ORG_ID
all.Organization
, all.Organization.read
, all.User
, all.User.read
, auditLog.*
, or auditLog.get
ORG_ID | ID associated with the organization | 575ed6e87ae143cd83dc4aa8 |
AUDIT_LOG_ID | ID associated with the audit log | 57955788124b37010084c053 |
https://api.losant.com/orgs/ORG_ID/audit-logs/AUDIT_LOG_ID
Code | Type | Description |
200 | Audit Log | Audit log information |
404 | Error | Error if audit log was not found |
Audit Log
Schema for a single Audit Log entry
Audit Log Schema
- ▶{} 20 keys
Audit Log Example
- ▶{} 17 keys
- "586e9d5151265cb9d72f6ec6"
- "575ed6e87ae143cd83dc4aa8"
- "Application"
- "My Application"
- "575ed70c7ae143cd83dc4aa9"
- "User"
- "actor@example.com"
- "application"
- "delete"
- {} 0 keys
- {} 0 keys
- 200
