Data Table Actions
https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID
Below are the various requests that can be performed against the Data Table resource, as well as the expected parameters and the potential responses.
Add Column
Adds a new column to this data table
POST https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/column
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, dataTable.*, or dataTable.addColumn.
DATA_TABLE_IDID associated with the data table575ed78e7ae143cd83dc4aab
The body of the request should be serialized JSON that validates against the Data Table Column schema. For example, the following would be a valid body for this request:
"name": "myColumn3",
"dataType": "string",
"constraint": "optional",
"defaultValue": "aDefault"
-d '{"name":"myColumn3","dataType":"string","constraint":"optional","defaultValue":"aDefault"}' \
CodeTypeDescription
200Data TableUpdated data table information
CodeTypeDescription
404ErrorError if data table was not found
Delete
Deletes a data table
DELETE https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, dataTable.*, or dataTable.delete.
CodeTypeDescription
200SuccessIf data table was successfully deleted
CodeTypeDescription
Retrieves information on a data table
GET https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.cli, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.cli, all.User.read, dataTable.*, or dataTable.get.
CodeTypeDescription
200Data TableData table information
CodeTypeDescription
Patch
Updates information about a data table
PATCH https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, dataTable.*, or dataTable.patch.
The body of the request should be serialized JSON that validates against the Data Table Patch schema. For example, the following would be a valid body for this request:
"name": "My Updated Data Table"
-d '{"name":"My Updated Data Table"}' \
CodeTypeDescription
CodeTypeDescription
Remove Column
Removes a column from this data table
DELETE https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/column
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, dataTable.*, or dataTable.removeColumn.
columnNameYName of the column to removecolumnName=myColumnName
https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/column?columnName=myColumnName
CodeTypeDescription
CodeTypeDescription
Data Table
Schema for a single Data Table
Data Table Schema
  • {} 3 keys
    • "object"
    • {} 8 keys
      • {} 2 keys
        • {} 2 keys
          • {} 2 keys
            • {} 2 keys
              • {} 2 keys
                • {} 3 keys
                  • {} 2 keys
                    • {} 3 keys
                  Data Table Example
                  • {} 7 keys
                    • "596e6ce831761df4231708f1"
                    • "575ec8687ae143cd83dc4a97"
                    • "2016-06-13T04:00:00.000Z"
                    • "My Data Table"
                    • [] 2 items
                    Data Table Column
                    Schema for a single Data Table Column
                    Data Table Column Schema
                    • {} 5 keys
                      • "object"
                      • {} 4 keys
                        • {} 2 keys
                          • {} 2 keys
                            • {} 2 keys
                              • {} 1 key
                              • [] 3 items
                                • false
                              Data Table Column Example
                              • {} 4 keys
                                • "myColumn3"
                                • "string"
                                • "optional"
                                • "aDefault"
                              Data Table Patch
                              Schema for the body of a Data Table modification request
                              Data Table Patch Schema
                              • {} 4 keys
                                • "object"
                                • {} 2 keys
                                  • {} 3 keys
                                    • {} 2 keys
                                    • false
                                  Data Table Patch Example
                                  • {} 1 key
                                    • "My Updated Data Table"
                                  • {} 3 keys
                                    • "object"
                                    • {} 2 keys
                                      • {} 1 key
                                        • {} 1 key
                                      • {} 2 keys
                                        • "NotFound"
                                        • "Application was not found"
                                      Success
                                      Success Schema
                                      • {} 3 keys
                                        • "object"
                                        • {} 1 key
                                          • {} 2 keys
                                        Success Example
                                        • {} 1 key
                                          • true
