Data Table Rows Actions
/data-tables/DATA_TABLE_ID
/rows
Below are the various requests that can be performed against the Data Table Rows resource, as well as the expected parameters and the potential responses.
Delete
Delete rows from a data table
/rows/delete
all.Application
, all.Organization
, all.User
, dataTableRows.*
, or dataTableRows.delete
DATA_TABLE_ID | ID associated with the data table | 575ed78e7ae143cd83dc4aab |
limit | N | Limit number of rows to delete from data table | 1000 | limit=10 |
The body of the request should be serialized JSON that validates against the Advanced Query schema. For example, the following would be a valid body for this request:
"$or": [
"level": {
"$ne": "myValue"
"level": 5
https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows/delete
Code | Type | Description |
200 | Data Table Rows Delete | If request successfully deletes a set of Data Table rows |
404 | Error | Error if data table was not found |
Export
Request an export of the data table's data
/rows/export
all.Application
, all.Application.read
, all.Organization
, all.Organization.read
, all.User
, all.User.read
, dataTableRows.*
, or dataTableRows.export
The body of the request should be serialized JSON that validates against the Data Table Rows Export schema. For example, the following would be a valid body for this request:
"email": "email@example.com",
"query": {
"$or": [
"myColumn1": {
"$ne": "myValue"
"myColumn2": 5
"queryOptions": {
"limit": 10000
-d '{"email":"email@example.com","query":{"$or":[{"myColumn1":{"$ne":"myValue"}},{"myColumn2":5}]},"queryOptions":{"limit":10000}}' \
https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows/export
202 | Job Enqueued API Result | If request was successfully queued |
Returns the rows for a data table
/rows
all.Application
, all.Application.cli
, all.Organization
, all.User
, all.User.cli
, all.User.read
, dataTableRows.*
, or dataTableRows.get
sortColumn | N | Column to sort the rows by | sortColumn=myColumnName | |
sortDirection | N | Direction to sort the rows by. Accepted values are: asc, desc | asc | sortDirection=asc |
limit | N | How many rows to return | 1000 | limit=0 |
offset | N | How many rows to skip | 0 | offset=0 |
includeFields | N | Comma-separated list of fields to include in resulting rows. When not provided, returns all fields. | includeFields=id,createdAt |
200 | Data Table Rows | Collection of data table rows |
Inserts a new row(s) into a data table
/rows
all.Application
, all.Organization
, all.User
, dataTableRows.*
, or dataTableRows.post
The body of the request should be serialized JSON that validates against the Data Table Row Insert schema. For example, the following would be a valid body for this request:
"myColumn1": "myValue"
-d '{"myColumn1":"myValue"}' \
201 | Data Table Row Insert Result | Successfully created data table row, or bulk insert count |
Query
Queries for rows from a data table
/rows/query
all.Application
, all.Organization
, all.User
, all.User.read
, dataTableRows.*
, or dataTableRows.query
"$or": [
"level": {
"$ne": "myValue"
"level": 5
https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows/query
Truncate
Delete all data in the data table
/rows/truncate
all.Application
, all.Organization
, all.User
, dataTableRows.*
, or dataTableRows.truncate
https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows/truncate
200 | Success | If request successfully deleted all rows in the data table, this will not send workflow data table deletion triggers |
Advanced Query
Schema for advanced filters and queries
Advanced Query Schema
Advanced Query Example
- ▶[] 2 items
Schema for inserting a data table row or rows
Data Table Row Insert Schema
- ▶[] 2 items
Data Table Row Insert Example
- "myValue"
Schema for a the result of a single or multiple row insert
Data Table Row Insert Result Schema
- ▶[] 2 items
Data Table Row Insert Result Example
- "596fbb703fc088453872e609"
- "myValue"
- 5
Data Table Rows
Schema for a collection of Data Table Rows
Data Table Rows Schema
- ▶{} 10 keys
Data Table Rows Example
- ▶{} 9 keys
- 1
- 4
- 0
- 1
- "myColumn1"
- "asc"
- "596e6ce831761df4231708f1"
Schema for response to data table rows removal
Data Table Rows Delete Schema
Data Table Rows Delete Example
- 100
Schema for the body of a data table export
Data Table Rows Export Schema
- ▶{} 6 keys
Data Table Rows Export Example
- "email@example.com"
Job Enqueued API Result Schema
Job Enqueued API Result Example
- "clnHvJbyVkOWAZwYAwLP4"
Success
Success Schema
Success Example
