Device Attributes Actions
https://api.losant.com/applications/APPLICATION_ID/devices/DEVICE_ID/attributes
Below are the various requests that can be performed against the Device Attributes resource, as well as the expected parameters and the potential responses.
Returns the attributes for a device
GET https://api.losant.com/applications/APPLICATION_ID/devices/DEVICE_ID/attributes
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Device, all.Device.read, all.Organization, all.Organization.read, all.User, all.User.read, deviceAttributes.*, or deviceAttributes.get.
DEVICE_IDID associated with the device575ecf887ae143cd83dc4aa2
sortFieldNField to sort the results by. Accepted values are: name, dataTypenamesortField=status
filterFieldNField to filter the results by. Blank or not provided means no filtering. Accepted values are: name, dataTypefilterField=status
filterNFilter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering.filter=number
CodeTypeDescription
200Device AttributesCollection of device attributes
CodeTypeDescription
404ErrorError if device was not found
Adds a new attribute to a device
POST https://api.losant.com/applications/APPLICATION_ID/devices/DEVICE_ID/attributes
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, deviceAttributes.*, or deviceAttributes.post.
The body of the request should be serialized JSON that validates against the Device Attribute Post schema. For example, the following would be a valid body for this request:
"name": "voltage",
"dataType": "number"
-d '{"name":"voltage","dataType":"number"}' \
CodeTypeDescription
201Device AttributeSuccessfully created device attribute
CodeTypeDescription
Device Attribute
Schema for a single Device Attribute
Device Attribute Schema
  • {} 3 keys
    • "object"
    • {} 8 keys
      • {} 2 keys
        • {} 2 keys
          • {} 2 keys
            • {} 2 keys
              • {} 3 keys
                • {} 3 keys
                  • {} 2 keys
                    • {} 2 keys
                  Device Attribute Example
                  • {} 4 keys
                    • "575ecf887ae143cd83dc4aa2"
                    • "575ec8687ae143cd83dc4a97"
                    • "voltage"
                    • "number"
                  Schema for the body of a Device Attribute creation request
                  Device Attribute Post Schema
                  • {} 5 keys
                    • "object"
                    • {} 6 keys
                      • {} 2 keys
                        • {} 2 keys
                          • {} 2 keys
                            • {} 2 keys
                              • {} 3 keys
                                • {} 3 keys
                                • [] 2 items
                                  • false
                                Device Attribute Post Example
                                • {} 2 keys
                                  • "voltage"
                                  • "number"
                                Device Attributes
                                Schema for a collection of Device Attributes
                                Device Attributes Schema
                                • {} 3 keys
                                  • "object"
                                  • {} 9 keys
                                    • {} 2 keys
                                      • {} 1 key
                                        • {} 1 key
                                          • {} 1 key
                                            • {} 1 key
                                              • {} 1 key
                                                • {} 2 keys
                                                  • {} 2 keys
                                                    • {} 2 keys
                                                  Device Attributes Example
                                                  • {} 7 keys
                                                    • [] 1 item
                                                      • 1
                                                      • 1
                                                      • "name"
                                                      • "asc"
                                                    • {} 3 keys
                                                      • "object"
                                                      • {} 2 keys
                                                        • {} 1 key
                                                          • {} 1 key
                                                        • {} 2 keys
                                                          • "NotFound"
                                                          • "Application was not found"
