Edge Deployment Actions
https://api.losant.com/applications/APPLICATION_ID/edge/deployments/EDGE_DEPLOYMENT_ID
Below are the various requests that can be performed against the Edge Deployment resource, as well as the expected parameters and the potential responses.
Retrieves information on an edge deployment
GET https://api.losant.com/applications/APPLICATION_ID/edge/deployments/EDGE_DEPLOYMENT_ID
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, edgeDeployment.*, or edgeDeployment.get.
| EDGE_DEPLOYMENT_ID | ID associated with the edge deployment | 575ed78e7ae143cd83dc4aab |
| 200 | Edge Deployment | Edge deployment information |
| 404 | Error | Error if edge deployment was not found |
Edge Deployment
Schema for a single deployment of an edge workflow to an edge device
Edge Deployment Schema
- ▶{} 17 keys
Edge Deployment Example
- ▶{} 10 keys
- "5a591be186b70d7b9f9b0954"
- "575ecf887ae143cd83dc4aa2"
- "575ed18f7ae143cd83dc4aa6"
- "v1.4.0"
- null
