Edge Deployments Actions
https://api.losant.com/applications/APPLICATION_ID/edge/deployments
Below are the various requests that can be performed against the Edge Deployments resource, as well as the expected parameters and the potential responses.
Returns the edge deployments for an application
GET https://api.losant.com/applications/APPLICATION_ID/edge/deployments
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, edgeDeployments.*, or edgeDeployments.get.
| sortField | N | Field to sort the results by. Accepted values are: id, deviceId, flowId, desiredVersion, currentVersion, creationDate, lastUpdated | lastUpdated | sortField=creationDate |
| deviceId | N | Filter deployments to the given Device ID | deviceId=575ecf887ae143cd83dc4aa2 | |
| version | N | Filter deployments to the given Workflow Version (matches against both current and desired) | version=myFlowVersion | |
| filterEmpty | N | Filter out deployments where both the current and desired version are null. | filterEmpty=true | |
| flowId | N | Filter deployments to the given Workflow ID | flowId=575ed18f7ae143cd83dc4aa6 |
| 200 | Edge Deployments | Collection of edge deployments |
Release
Deploy an edge workflow version to one or more edge devices. Version can be blank, if removal is desired.
POST https://api.losant.com/applications/APPLICATION_ID/edge/deployments/release
all.Application, all.Organization, all.User, edgeDeployments.*, or edgeDeployments.release.
The body of the request should be serialized JSON that validates against the Edge Deployment Release schema. For example, the following would be a valid body for this request:
"flowId": "575ed18f7ae143cd83dc4aa6",
"version": "v1.2.3",
"deviceIds": [
"575ecf887ae143cd83dc4aa2"
-d '{"flowId":"575ed18f7ae143cd83dc4aa6","version":"v1.2.3","deviceIds":["575ecf887ae143cd83dc4aa2"]}' \
| 201 | Success | If deployment release has been initiated successfully |
Remove
Remove all edge deployments from a device, remove all edge deployments of a workflow, or remove a specific workflow from a specific device
POST https://api.losant.com/applications/APPLICATION_ID/edge/deployments/remove
all.Application, all.Organization, all.User, edgeDeployments.*, or edgeDeployments.remove.
The body of the request should be serialized JSON that validates against the Edge Deployment Remove schema. For example, the following would be a valid body for this request:
"deviceId": null
-d '{"flowId":"575ed18f7ae143cd83dc4aa6","deviceId":null}' \
| 201 | Success | If deployment removal has been initiated successfully |
Replace
Replace deployments of an edge workflow version with a new version. New version can be blank, if removal is desired.
POST https://api.losant.com/applications/APPLICATION_ID/edge/deployments/replace
all.Application, all.Organization, all.User, edgeDeployments.*, or edgeDeployments.replace.
The body of the request should be serialized JSON that validates against the Edge Deployment Replace schema. For example, the following would be a valid body for this request:
"oldVersion": "v1.2.3",
"newVersion": "v1.2.4"
-d '{"flowId":"575ed18f7ae143cd83dc4aa6","oldVersion":"v1.2.3","newVersion":"v1.2.4"}' \
| 201 | Success | If deployment replacement has been initiated successfully |
Schema for deploying an edge workflow to one or more edge devices
Edge Deployment Release Schema
- ▶[] 2 items
Edge Deployment Release Example
- "575ed18f7ae143cd83dc4aa6"
- "v1.2.3"
Schema for removing edge deployments. Can remove a specific workflow from a specific device, can remove all workflows from a specific device, or can remove a specific workflow from all devices.
Edge Deployment Remove Schema
- ▶[] 2 items
Edge Deployment Remove Example
- null
Schema for replacing a deployment of a workflow version with a different workflow version
Edge Deployment Replace Schema
- ▶[] 3 items
Edge Deployment Replace Example
- "v1.2.3"
- "v1.2.4"
Edge Deployments
Schema for a collection of Edge Deployments
Edge Deployments Schema
- ▶{} 7 keys
Edge Deployments Example
- ▶{} 8 keys
- 1
- 4
- 1
- 0
- "id"
- "asc"
Success
Success Schema
Success Example
