Embedded Deployment Actions
/embedded/deployments/EMBEDDED_DEPLOYMENT_ID
Below are the various requests that can be performed against the Embedded Deployment resource, as well as the expected parameters and the potential responses.
Retrieves information on an embedded deployment
all.Application
, all.Application.read
, all.Organization
, all.Organization.read
, all.User
, all.User.read
, embeddedDeployment.*
, or embeddedDeployment.get
EMBEDDED_DEPLOYMENT_ID | ID associated with the embedded deployment | 575ed78e7ae143cd83dc4aab |
https://api.losant.com/applications/APPLICATION_ID/embedded/deployments/EMBEDDED_DEPLOYMENT_ID
Code | Type | Description |
200 | Embedded Deployment | Embedded deployment information |
404 | Error | Error if embedded deployment was not found |
Embedded Deployment
Schema for a single deployment of embedded workflows to embedded devices
Embedded Deployment Schema
- ▶{} 13 keys
Embedded Deployment Example
- ▶{} 10 keys
- "5a591be186b70d7b9f9b0954"
- "nullVersion"
- "1615500683"
