Embedded Deployments Actions
https://api.losant.com/applications/APPLICATION_ID/embedded/deployments
Below are the various requests that can be performed against the Embedded Deployments resource, as well as the expected parameters and the potential responses.
Export
Request an export of the compiled WASM files for a current deployment
POST https://api.losant.com/applications/APPLICATION_ID/embedded/deployments/export
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, embeddedDeployments.*, or embeddedDeployments.export.
The body of the request should be serialized JSON that validates against the Embedded Deployment Export schema. For example, the following would be a valid body for this request:
"email": "email@example.com",
"deviceId": "575ecf887ae143cd83dc4aa2"
CodeTypeDescription
202Job Enqueued API ResultIf generation of export was successfully started
CodeTypeDescription
404ErrorError if deployment was not found
Returns the embedded deployments for an application
GET https://api.losant.com/applications/APPLICATION_ID/embedded/deployments
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, embeddedDeployments.*, or embeddedDeployments.get.
sortFieldNField to sort the results by. Accepted values are: id, creationDate, lastUpdatedlastUpdatedsortField=creationDate
sortDirectionNDirection to sort the results by. Accepted values are: asc, descdescsortDirection=asc
perPageNHow many items to return per page1000perPage=10
deviceIdNFilter deployments to the given Device IDdeviceId=575ecf887ae143cd83dc4aa2
versionNFilter deployments to the given Workflow Version (matches against both current and desired)version=myFlowVersion
flowIdNFilter deployments to the given Workflow IDflowId=575ed18f7ae143cd83dc4aa6
CodeTypeDescription
200Embedded DeploymentsCollection of embedded deployments
CodeTypeDescription
404ErrorError if application or device was not found
Release
Deploy an embedded workflow version to one or more embedded devices. Version can be blank, if removal is desired.
POST https://api.losant.com/applications/APPLICATION_ID/embedded/deployments/release
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, embeddedDeployments.*, or embeddedDeployments.release.
The body of the request should be serialized JSON that validates against the Embedded Deployment Release schema. For example, the following would be a valid body for this request:
"flowId": "575ed18f7ae143cd83dc4aa6",
"version": "v1.2.3",
"deviceIds": [
-d '{"flowId":"575ed18f7ae143cd83dc4aa6","version":"v1.2.3","deviceIds":["575ecf887ae143cd83dc4aa2"]}' \
CodeTypeDescription
201SuccessIf deployment release has been initiated successfully
CodeTypeDescription
Remove
Remove all embedded deployments from a device, remove all embedded deployments of a workflow, or remove a specific workflow from a specific device
POST https://api.losant.com/applications/APPLICATION_ID/embedded/deployments/remove
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, embeddedDeployments.*, or embeddedDeployments.remove.
The body of the request should be serialized JSON that validates against the Embedded Deployment Remove schema. For example, the following would be a valid body for this request:
"deviceId": null
-d '{"flowId":"575ed18f7ae143cd83dc4aa6","deviceId":null}' \
CodeTypeDescription
201SuccessIf deployment removal has been initiated successfully
CodeTypeDescription
Replace
Replace deployments of an embedded workflow version with a new version. New version can be blank, if removal is desired.
POST https://api.losant.com/applications/APPLICATION_ID/embedded/deployments/replace
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, embeddedDeployments.*, or embeddedDeployments.replace.
The body of the request should be serialized JSON that validates against the Embedded Deployment Replace schema. For example, the following would be a valid body for this request:
"oldVersion": "v1.2.3",
"newVersion": "v1.2.4"
-d '{"flowId":"575ed18f7ae143cd83dc4aa6","oldVersion":"v1.2.3","newVersion":"v1.2.4"}' \
CodeTypeDescription
201SuccessIf deployment replacement has been initiated successfully
CodeTypeDescription
Schema for the body of a compiled embedded deployment files request
Embedded Deployment Export Schema
  • {} 4 keys
    • "object"
    • {} 10 keys
      • {} 3 keys
        • {} 3 keys
          • {} 2 keys
            • {} 2 keys
              • {} 1 key
                • {} 1 key
                  • {} 3 keys
                    • {} 1 key
                      • {} 1 key
                        • {} 1 key
                        • false
                      Embedded Deployment Export Example
                      • {} 2 keys
                        • "email@example.com"
                        • "575ecf887ae143cd83dc4aa2"
                      Schema for deploying an embedded workflow to one or more edge devices
                      Embedded Deployment Release Schema
                      • {} 5 keys
                        • "object"
                        • {} 5 keys
                          • {} 2 keys
                            • {} 3 keys
                              • {} 3 keys
                                • {} 3 keys
                                  • {} 3 keys
                                  • false
                                  • [] 2 items
                                  Embedded Deployment Release Example
                                  • {} 3 keys
                                    • "575ed18f7ae143cd83dc4aa6"
                                    • "v1.2.3"
                                    • [] 1 item
                                    Schema for removing embedded deployments. Can remove a specific workflow from a specific device, can remove all workflows from a specific device, or can remove a specific workflow from all devices.
                                    Embedded Deployment Remove Schema
                                    • {} 5 keys
                                      • "object"
                                      • {} 2 keys
                                        • {} 2 keys
                                          • {} 2 keys
                                          • false
                                          • [] 2 items
                                          Embedded Deployment Remove Example
                                          • {} 2 keys
                                            • null
                                          Schema for replacing a deployment of a workflow version with a different workflow version
                                          Embedded Deployment Replace Schema
                                          • {} 5 keys
                                            • "object"
                                            • {} 3 keys
                                              • {} 2 keys
                                                • {} 3 keys
                                                  • {} 3 keys
                                                  • false
                                                  • [] 3 items
                                                  Embedded Deployment Replace Example
                                                  • {} 3 keys
                                                    • "v1.2.3"
                                                    • "v1.2.4"
                                                  Schema for a collection of Embedded Deployments
                                                  Embedded Deployments Schema
                                                  • {} 3 keys
                                                    • "object"
                                                    • {} 7 keys
                                                      • {} 2 keys
                                                        • {} 1 key
                                                          • {} 1 key
                                                            • {} 2 keys
                                                              • {} 2 keys
        • {} 2 keys
        • {} 3 keys
        Embedded Deployments Example
        • {} 8 keys
        • [] 1 item
        • 1
        • 4
        • 1
        • 0
        • "id"
        • "asc"
        • "575ec8687ae143cd83dc4a97"
        • {} 3 keys
        • "object"
        • {} 2 keys
        • {} 1 key
        • {} 1 key
        • {} 2 keys
        • "NotFound"
        • "Application was not found"
        Job Enqueued API Result Schema
        • {} 3 keys
        • "object"
        • {} 3 keys
        • {} 2 keys
        • {} 2 keys
        • {} 2 keys
        Job Enqueued API Result Example
        • {} 3 keys
        • true
        • "clnHvJbyVkOWAZwYAwLP4"
        • true
        Success
        Success Schema
        • {} 3 keys
        • "object"
        • {} 1 key
        • {} 2 keys
        Success Example
        • {} 1 key
        • true
