Experience Endpoints Actions
https://api.losant.com/applications/APPLICATION_ID/experience/endpoints
Below are the various requests that can be performed against the Experience Endpoints resource, as well as the expected parameters and the potential responses.
Returns the experience endpoints for an application
GET https://api.losant.com/applications/APPLICATION_ID/experience/endpoints
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, experienceEndpoints.*, or experienceEndpoints.get.
sortFieldNField to sort the results by. Accepted values are: order, method, route, id, creationDate, requestCount, lastUpdatedordersortField=order
filterFieldNField to filter the results by. Blank or not provided means no filtering. Accepted values are: method, routefilterField=method
filterNFilter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering.filter=my*route
experienceGroupIdNFilter endpoints to those only in the specified groupexperienceGroupId=575ec8687ae143cd83dc4a97
requestCountDurationNIf set, a count of recent requests is included on each endpoint for the duration requested (milliseconds)requestCountDuration=86400000
versionNReturn the experience endpoints belonging to this versiondevelopversion=develop
CodeTypeDescription
200Experience EndpointsCollection of experience endpoints
CodeTypeDescription
Create a new experience endpoint for an application
POST https://api.losant.com/applications/APPLICATION_ID/experience/endpoints
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, experienceEndpoints.*, or experienceEndpoints.post.
The body of the request should be serialized JSON that validates against the Experience Endpoint Post schema. For example, the following would be a valid body for this request:
"route": "/my/route/{id}",
"method": "get",
"access": "public"
-d '{"route":"/my/route/{id}","method":"get","access":"public"}' \
CodeTypeDescription
201Experience EndpointSuccessfully created experience endpoint
CodeTypeDescription
Stats
Get statistics about endpoint requests
GET https://api.losant.com/applications/APPLICATION_ID/experience/endpoints/stats
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, experienceEndpoints.*, or experienceEndpoints.stats.
statGroupingNField to group the statistics by. Accepted values are: statusCode, endpointId, version, domainstatusCodestatGrouping=statusCode
durationNDuration in milliseconds86400000duration=86400000
endNEnd of time range in milliseconds since epoch0end=0
resolutionNResolution in milliseconds3600000resolution=3600000
versionFilterNFilters the stats to a particular experience versionversionFilter=myVersion
domainFilterNFilters the stats to a particular experience domain or slugdomainFilter=mycustomdomain.com
statusCodeFilterNFilters the stats to a particular status codestatusCodeFilter=200
endpointIdFilterNFilters the stats to a particular endpointendpointIdFilter=575ec8687ae143cd83dc4a98
CodeTypeDescription
200Experience Endpoint StatsStatistics for endpoint requests
CodeTypeDescription
  • {} 3 keys
    • "object"
    • {} 2 keys
      • {} 1 key
        • {} 1 key
      • {} 2 keys
        • "NotFound"
        • "Application was not found"
      Experience Endpoint
      Schema for a single Experience Endpoint
      Experience Endpoint Schema
      • {} 3 keys
        • "object"
        • {} 19 keys
          • {} 2 keys
            • {} 2 keys
              • {} 2 keys
                • {} 2 keys
                  • {} 2 keys
                    • {} 2 keys
                      • {} 2 keys
                        • {} 2 keys
                          • {} 2 keys
                            • {} 2 keys
                              • {} 3 keys
                                • {} 1 key
                                  • {} 2 keys
                                    • {} 2 keys
                                      • {} 2 keys
                                        • {} 3 keys
                                          • {} 1 key
                                            • {} 1 key
                                              • {} 2 keys
                                            Experience Endpoint Example
                                            • {} 10 keys
                                              • "58c1de6c8f812590d8e82980"
                                              • "575ec8687ae143cd83dc4a97"
                                              • "2016-06-13T04:00:00.000Z"
                                              • "/my/route/{id}"
                                              • true
                                              • "get"
                                              • "group"
                                              • [] 1 item
                                              Schema for the body of an Experience Endpoint creation request
                                              Experience Endpoint Post Schema
                                              • {} 5 keys
                                                • "object"
                                                • {} 10 keys
                                                  • {} 2 keys
                                                    • {} 3 keys
                                                      • {} 1 key
                                                        • {} 2 keys
                                                          • {} 2 keys
                                                            • {} 2 keys
                                                              • {} 3 keys
        • {} 3 keys
        • {} 1 key
        • {} 1 key
        • false
        • [] 2 items
        Experience Endpoint Post Example
        • {} 3 keys
        • "/my/route/{id}"
        • "get"
        • "public"
        Schema for stats for an experience's endpoints
        Experience Endpoint Stats Schema
        • {} 3 keys
        • "object"
        • {} 1 key
        Experience Endpoint Stats Example
        • {} 2 keys
        • [] 2 items
        • [] 2 items
        Schema for a collection of Experience Endpoints
        Experience Endpoints Schema
        • {} 3 keys
        • "object"
        • {} 10 keys
        • {} 2 keys
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 2 keys
        • {} 2 keys
        • {} 2 keys
        • {} 1 key
        Experience Endpoints Example
        • {} 8 keys
        • [] 1 item
        • 1
        • 4
        • 1
        • 0
        • "name"
        • "asc"
