Experience Groups Actions
https://api.losant.com/applications/APPLICATION_ID/experience/groups
Below are the various requests that can be performed against the Experience Groups resource, as well as the expected parameters and the potential responses.
Returns the experience groups for an application
GET https://api.losant.com/applications/APPLICATION_ID/experience/groups
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, experienceGroups.*, or experienceGroups.get.
sortFieldNField to sort the results by. Accepted values are: name, id, creationDate, lastUpdatednamesortField=name
filterFieldNField to filter the results by. Blank or not provided means no filtering. Accepted values are: namefilterField=name
filterNFilter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering.filter=my*group
queryNExperience group filter JSON object which overrides the filter and filterField fields. See Advanced Experience Group Query for more details.query={"name":"My Great Group","lastUpdated":"2022-01-30T17:18:11.911Z"}
CodeTypeDescription
200Experience GroupsCollection of experience groups
CodeTypeDescription
Create a new experience group for an application
POST https://api.losant.com/applications/APPLICATION_ID/experience/groups
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, experienceGroups.*, or experienceGroups.post.
The body of the request should be serialized JSON that validates against the Experience Group Post schema. For example, the following would be a valid body for this request:
"name": "My Group",
"experienceUserIds": [
"575ed70c7ae143cd83dc4aa9",
"675ed70c7ae143cd83dc4aa9"
"experienceEndpointIds": [
"58b9d743cbfafe1be675744b",
"58b9d743cbfafe1be675744c"
"deviceIds": [
"58b9d743cbfafe1be675744d"
"deviceTags": [
"key": "floor",
"value": "8"
"parentId": "58b9d743cbfafe1be675744e"
-d '{"name":"My Group","experienceUserIds":["575ed70c7ae143cd83dc4aa9","675ed70c7ae143cd83dc4aa9"],"experienceEndpointIds":["58b9d743cbfafe1be675744b","58b9d743cbfafe1be675744c"],"deviceIds":["58b9d743cbfafe1be675744d"],"deviceTags":[{"key":"floor","value":"8"}],"parentId":"58b9d743cbfafe1be675744e"}' \
CodeTypeDescription
201Experience GroupSuccessfully created experience group
CodeTypeDescription
Schema for advanced experience group queries
Advanced Experience Group Query Schema
  • {} 4 keys
    • "object"
    • {} 12 keys
      • {} 3 keys
        • {} 3 keys
          • {} 3 keys
            • {} 1 key
              • {} 1 key
                • {} 1 key
                  • {} 1 key
                    • {} 1 key
                      • {} 1 key
                        • {} 1 key
                          • {} 1 key
                            • {} 1 key
                            • false
                          Advanced Experience Group Query Example
                          • {} 2 keys
                            • "My Great Group"
                            • "2022-01-30T17:18:11.911Z"
                          • {} 3 keys
                            • "object"
                            • {} 2 keys
                              • {} 1 key
                                • {} 1 key
                              • {} 2 keys
                                • "NotFound"
                                • "Application was not found"
                              Experience Group
                              Schema for a single Experience Group
                              Experience Group Schema
                              • {} 3 keys
                                • "object"
                                • {} 17 keys
                                  • {} 2 keys
                                    • {} 2 keys
                                      • {} 2 keys
                                        • {} 2 keys
                                          • {} 2 keys
                                            • {} 3 keys
                                              • {} 2 keys
                                                • {} 3 keys
                                                  • {} 3 keys
                                                    • {} 3 keys
                                                      • {} 3 keys
                                                        • {} 3 keys
                                                          • {} 2 keys
                                                            • {} 1 key
                                                              • {} 3 keys
        • {} 1 key
        • {} 1 key
        Experience Group Example
        • {} 8 keys
        • "58b9d794cbfafe1be675744f"
        • "575ec8687ae143cd83dc4a97"
        • "2016-06-13T04:00:00.000Z"
        • "My Group"
        • [] 2 items
        • [] 2 items
        Schema for the body of an Experience Group creation request
        Experience Group Post Schema
        • {} 5 keys
        • "object"
        • {} 9 keys
        • {} 3 keys
        • {} 2 keys
        • {} 3 keys
        • {} 3 keys
        • {} 3 keys
        • {} 3 keys
        • {} 3 keys
        • {} 2 keys
        • {} 1 key
        • false
        • [] 1 item
        Experience Group Post Example
        • {} 6 keys
        • "My Group"
        • [] 2 items
        • [] 2 items
        • [] 1 item
        • [] 1 item
        • "58b9d743cbfafe1be675744e"
        Experience Groups
        Schema for a collection of Experience Groups
        Experience Groups Schema
        • {} 3 keys
        • "object"
        • {} 10 keys
        • {} 2 keys
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 2 keys
        • {} 2 keys
        Experience Groups Example
        • {} 8 keys
        • [] 1 item
        • 1
        • 4
        • 1
        • 0
        • "name"
        • "asc"
