Experience Slugs Actions
/experience/slugs
Below are the various requests that can be performed against the Experience Slugs resource, as well as the expected parameters and the potential responses.
Returns the experience slugs for an application
/experience/slugs
all.Application
, all.Application.cli
, all.Application.read
, all.Organization
, all.Organization.read
, all.User
, all.User.cli
, all.User.read
, experienceSlugs.*
, or experienceSlugs.get
https://api.losant.com/applications/APPLICATION_ID/experience/slugs
Code | Type | Description |
200 | Experience Slugs | Collection of experience slugs |
Create a new experience slug for an application
/experience/slugs
all.Application
, all.Organization
, all.User
, experienceSlugs.*
, or experienceSlugs.post
The body of the request should be serialized JSON that validates against the Experience Slug Post schema. For example, the following would be a valid body for this request:
"slug": "my-custom-slug",
"version": "develop"
-d '{"slug":"my-custom-slug","version":"develop"}' \
201 | Experience Slug | Successfully created experience slug |
Experience Slug
Schema for a single Experience Slug
Experience Slug Schema
- ▶{} 7 keys
Experience Slug Example
- ▶{} 7 keys
- "5b995e51ea9994b50d745284"
- "my-custom-slug"
- "develop"
Schema for the body of an Experience Slug creation request
Experience Slug Post Schema
Experience Slug Post Example
- "my-custom-slug"
- "develop"
Experience Slugs
Schema for a collection of Experience Slugs
Experience Slugs Schema
Experience Slugs Example
- 1
- 1
