Experience User Actions
https://api.losant.com/applications/APPLICATION_ID/experience/users/EXPERIENCE_USER_ID
Below are the various requests that can be performed against the Experience User resource, as well as the expected parameters and the potential responses.
Delete
Deletes an experience user
DELETE https://api.losant.com/applications/APPLICATION_ID/experience/users/EXPERIENCE_USER_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, experienceUser.*, or experienceUser.delete.
EXPERIENCE_USER_IDID associated with the experience user575ed78e7ae143cd83dc4aab
CodeTypeDescription
200SuccessIf experience user was successfully deleted
CodeTypeDescription
404ErrorError if experience user was not found
Retrieves information on an experience user
GET https://api.losant.com/applications/APPLICATION_ID/experience/users/EXPERIENCE_USER_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, experienceUser.*, or experienceUser.get.
CodeTypeDescription
200Experience UserExperience user information
CodeTypeDescription
Patch
Updates information about an experience user
PATCH https://api.losant.com/applications/APPLICATION_ID/experience/users/EXPERIENCE_USER_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, experienceUser.*, or experienceUser.patch.
The body of the request should be serialized JSON that validates against the Experience User Patch schema. For example, the following would be a valid body for this request:
"password": "aNewPassword",
"userTags": {
"customKey": "newCustomValue"
-d '{"password":"aNewPassword","userTags":{"customKey":"newCustomValue"}}' \
CodeTypeDescription
200Experience UserUpdated experience user information
CodeTypeDescription
  • {} 3 keys
    • "object"
    • {} 2 keys
      • {} 1 key
        • {} 1 key
      • {} 2 keys
        • "NotFound"
        • "Application was not found"
      Experience User
      Schema for a single Experience User
      Experience User Schema
      • {} 3 keys
        • "object"
        • {} 14 keys
          • {} 2 keys
            • {} 2 keys
              • {} 2 keys
                • {} 2 keys
                  • {} 2 keys
                    • {} 2 keys
                      • {} 2 keys
                        • {} 3 keys
                          • {} 2 keys
                            • {} 2 keys
                              • {} 3 keys
                                • {} 2 keys
                                  • {} 3 keys
                                    • {} 2 keys
                                  Experience User Example
                                  • {} 12 keys
                                    • "58b9d782cbfafe1be675744d"
                                    • "575ec8687ae143cd83dc4a97"
                                    • "2016-06-13T04:00:00.000Z"
                                    • "experienceuser@example.com"
                                    • "Example"
                                    • "Name"
                                    • "https://example.avatar.url/is_here.png"
                                    • {} 1 key
                                    Schema for the body of an Experience User modification request
                                    Experience User Patch Schema
                                    • {} 4 keys
                                      • "object"
                                      • {} 7 keys
                                        • {} 3 keys
                                          • {} 2 keys
                                            • {} 2 keys
                                              • {} 3 keys
                                                • {} 2 keys
                                                  • {} 3 keys
                                                    • {} 3 keys
                                                    • false
                                                  Experience User Patch Example
                                                  • {} 2 keys
                                                    • "aNewPassword"
                                                    • {} 1 key
                                                    Success
                                                    Success Schema
                                                    • {} 3 keys
                                                      • "object"
                                                      • {} 1 key
                                                        • {} 2 keys
                                                      Success Example
                                                      • {} 1 key
                                                        • true
