Experience Version Actions
/experience/versions/EXPERIENCE_VERSION_ID_OR_NAME
Below are the various requests that can be performed against the Experience Version resource, as well as the expected parameters and the potential responses.
Delete
Deletes an experience version
DELETE https://api.losant.com/applications/APPLICATION_ID
all.Application
, all.Application.cli
, all.Organization
, all.User
, all.User.cli
, experienceVersion.*
, or experienceVersion.delete
EXPERIENCE_VERSION_ID_OR_NAME | Version ID or version name associated with the experience version | 575ed78e7ae143cd83dc4aab |
https://api.losant.com/applications/APPLICATION_ID/experience/versions/EXPERIENCE_VERSION_ID_OR_NAME
Code | Type | Description |
200 | Success | If experience version was successfully deleted |
404 | Error | Error if experience version was not found |
Retrieves information on an experience version
all.Application
, all.Application.read
, all.Organization
, all.Organization.read
, all.User
, all.User.cli
, all.User.read
, or experienceVersion.get
200 | Experience Version | Experience version information |
Patch
Updates information about an experience version
PATCH https://api.losant.com/applications/APPLICATION_ID
all.Application
, all.Organization
, all.User
, all.User.cli
, or experienceVersion.patch
The body of the request should be serialized JSON that validates against the Experience Version Patch schema. For example, the following would be a valid body for this request:
"endpointDefaultCors": false
-d '{"endpointDefaultCors":false}' \
200 | Experience Version | Updated experience version information |
Experience Version
Schema for a single Experience Version
Experience Version Schema
- ▶{} 18 keys
Experience Version Example
- ▶{} 9 keys
- "5b995ec6ea9994b50d745285"
- "myVersionName"
Schema for the body of an Experience Version modification request
Experience Version Patch Schema
- ▶{} 7 keys
Experience Version Patch Example
Success
Success Schema
Success Example
