Experience Views Actions
https://api.losant.com/applications/APPLICATION_ID/experience/views
Below are the various requests that can be performed against the Experience Views resource, as well as the expected parameters and the potential responses.
Returns the experience views for an application
GET https://api.losant.com/applications/APPLICATION_ID/experience/views
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.cli, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.cli, all.User.read, experienceViews.*, or experienceViews.get.
sortFieldNField to sort the results by. Accepted values are: id, creationDate, name, lastUpdatednamesortField=name
filterFieldNField to filter the results by. Blank or not provided means no filtering. Accepted values are: namefilterField=name
filterNFilter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering.filter=my*view
viewTypeNFilter views to those only of the given type. Accepted values are: page, layout, componentviewType=page
versionNReturn the experience views belonging to this versiondevelopversion=develop
CodeTypeDescription
200Experience ViewsCollection of experience views
CodeTypeDescription
Create a new experience view for an application
POST https://api.losant.com/applications/APPLICATION_ID/experience/views
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.cli, all.Organization, all.User, all.User.cli, experienceViews.*, or experienceViews.post.
The body of the request should be serialized JSON that validates against the Experience View Post schema. For example, the following would be a valid body for this request:
"name": "My Page View",
"viewType": "page",
"body": "<p>{{data}}</p>",
"layoutId": "59cc5cad8246c6caed4b16c2",
"viewTags": {
"customKey": "customValue"
-d '{"name":"My Page View","viewType":"page","body":"<p>{{data}}</p>","layoutId":"59cc5cad8246c6caed4b16c2","viewTags":{"customKey":"customValue"}}' \
CodeTypeDescription
201Experience ViewSuccessfully created experience view
CodeTypeDescription
  • {} 3 keys
    • "object"
    • {} 2 keys
      • {} 1 key
        • {} 1 key
      • {} 2 keys
        • "NotFound"
        • "Application was not found"
      Experience View
      Schema for a single Experience View
      Experience View Schema
      • {} 3 keys
        • "object"
        • {} 17 keys
          • {} 2 keys
            • {} 2 keys
              • {} 2 keys
                • {} 2 keys
                  • {} 2 keys
                    • {} 2 keys
                      • {} 2 keys
                        • {} 2 keys
                          • {} 2 keys
                            • {} 3 keys
                              • {} 2 keys
                                • {} 2 keys
                                  • {} 2 keys
                                    • {} 3 keys
                                      • {} 2 keys
                                        • {} 3 keys
                                          • {} 3 keys
                                        Experience View Example
                                        • {} 10 keys
                                          • "59cc5c628246c6caed4b16c1"
                                          • "575ec8687ae143cd83dc4a97"
                                          • "2016-06-13T04:00:00.000Z"
                                          • "My Page View"
                                          • "page"
                                          • "<p>{{data}}</p>"
                                          • "59cc5cad8246c6caed4b16c2"
                                          • {} 1 key
                                          Schema for the body of an Experience View creation request
                                          Experience View Post Schema
                                          • {} 5 keys
                                            • "object"
                                            • {} 7 keys
                                              • {} 3 keys
                                                • {} 2 keys
                                                  • {} 2 keys
                                                    • {} 2 keys
                                                      • {} 2 keys
                                                        • {} 3 keys
                                                          • {} 3 keys
                                                          • false
                                                          • [] 2 items
                                                          Experience View Post Example
                                                          • {} 5 keys
                                                            • "My Page View"
                                                            • "page"
                                                            • "<p>{{data}}</p>"
                                                            • {} 1 key
                                                            Experience Views
                                                            Schema for a collection of Experience Views
                                                            Experience Views Schema
                                                            • {} 3 keys
                                                              • "object"
                                                              • {} 11 keys
        • {} 2 keys
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 2 keys
        • {} 2 keys
        • {} 2 keys
        Experience Views Example
        • {} 8 keys
        • [] 1 item
        • 1
        • 4
        • 1
        • 0
        • "name"
        • "asc"
