Instance Audit Log Actions
https://api.losant.com/instance/INSTANCE_ID
/audit-logs/INSTANCE_AUDIT_LOG_ID
Below are the various requests that can be performed against the Instance Audit Log resource, as well as the expected parameters and the potential responses.
Retrieves information on an instance audit log
GET https://api.losant.com/instance/INSTANCE_ID
all.Instance
, all.Instance.read
, all.User
, all.User.read
, instanceAuditLog.*
, or instanceAuditLog.get
INSTANCE_ID | ID associated with the instance | 575ec7417ae143cd83dc4a96 |
INSTANCE_AUDIT_LOG_ID | ID associated with the instance audit log | 57955788124b37010084c053 |
https://api.losant.com/instance/INSTANCE_ID/audit-logs/INSTANCE_AUDIT_LOG_ID
Code | Type | Description |
200 | Instance Audit Log | Instance audit log information |
404 | Error | Error if instance audit log was not found |
Instance Audit Log
Schema for a single Instance Audit Log entry
Instance Audit Log Schema
- ▶{} 20 keys
Instance Audit Log Example
- ▶{} 17 keys
- "586e9d5151265cb9d72f6ec6"
- "575ed6e87ae143cd83dc4aa8"
- "Organization"
- "My Org"
- "575ed70c7ae143cd83dc4aa9"
- "User"
- "actor@example.com"
- "organization"
- "delete"
- {} 0 keys
- {} 0 keys
- 200
