Instance Audit Logs Actions
https://api.losant.com/instance/INSTANCE_ID/audit-logs
Below are the various requests that can be performed against the Instance Audit Logs resource, as well as the expected parameters and the potential responses.
Returns the audit logs for the instance
GET https://api.losant.com/instance/INSTANCE_ID/audit-logs
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.read, all.User, all.User.read, instanceAuditLogs.*, or instanceAuditLogs.get.
INSTANCE_IDID associated with the instance575ec7417ae143cd83dc4a96
sortFieldNField to sort the results by. Accepted values are: creationDate, responseStatus, actorNamecreationDatesortField=creationDate
sortDirectionNDirection to sort the results by. Accepted values are: asc, descdescsortDirection=asc
startNStart of time range for audit log querystart=1465790400000
endNEnd of time range for audit log queryend=1465790400000
auditLogFilterNFilters for the audit log query. See Instance Audit Log Filter for more details.auditLogFilter[primaryTarget][0][type]=Organization&auditLogFilter[primaryTarget][1][type]=ApiToken&auditLogFilter[primaryTarget][1][id]=575ec8687ae143cd83dc4a97&auditLogFilter[actor][0][type]=User&auditLogFilter[actor][0][id]=575ed70c7ae143cd83dc4aa9
CodeTypeDescription
200Instance Audit LogsCollection of instance audit logs
CodeTypeDescription
404ErrorError if instance was not found
  • {} 3 keys
    • "object"
    • {} 2 keys
      • {} 1 key
        • {} 1 key
      • {} 2 keys
        • "NotFound"
        • "Application was not found"
      Schema for the filter of an instance audit log query
      Instance Audit Log Filter Schema
      • {} 4 keys
        • "object"
        • {} 5 keys
          • {} 2 keys
            • {} 2 keys
              • {} 2 keys
                • {} 2 keys
                  • {} 2 keys
                  • false
                Instance Audit Log Filter Example
                • {} 2 keys
                  • [] 2 items
                    • [] 1 item
                    Instance Audit Logs
                    Schema for a collection of Instance Audit Logs
                    Instance Audit Logs Schema
                    • {} 3 keys
                      • "object"
                      • {} 8 keys
                        • {} 2 keys
                          • {} 1 key
                            • {} 1 key
                              • {} 1 key
                                • {} 1 key
                                  • {} 1 key
                                    • {} 2 keys
                                      • {} 2 keys
                                    Instance Audit Logs Example
                                    • {} 8 keys
                                      • [] 1 item
                                        • 1
                                        • 4
                                        • 1
                                        • 0
                                        • "creationDate"
                                        • "desc"
                                        • "575ed6e87ae143cd83dc4aa8"
