Instance Custom Node Actions
https://api.losant.com/instances/INSTANCE_ID
/nodes/INSTANCE_CUSTOM_NODE_ID
Below are the various requests that can be performed against the Instance Custom Node resource, as well as the expected parameters and the potential responses.
Delete
Deletes a Custom Node
DELETE https://api.losant.com/instances/INSTANCE_ID
all.Instance
, all.User
, instanceCustomNode.*
, or instanceCustomNode.delete
INSTANCE_ID | ID associated with the instance | 575ec7417ae143cd83dc4a96 |
INSTANCE_CUSTOM_NODE_ID | ID associated with the Custom Node | 575ec7417ae143cd83dc4a95 |
https://api.losant.com/instances/INSTANCE_ID/nodes/INSTANCE_CUSTOM_NODE_ID
Code | Type | Description |
200 | Success | If Custom Node was successfully deleted |
404 | Error | Error if Custom Node was not found |
Errors
Get information about errors that occurred during runs of this Custom Node
GET https://api.losant.com/instances/INSTANCE_ID
/errors
all.Instance
, all.Instance.read
, all.User
, all.User.read
, or instanceCustomNode.errors
duration | N | Duration of time range in milliseconds | 86400000 | duration=86400000 |
end | N | End of time range in milliseconds since epoch | 0 | end=0 |
limit | N | Maximum number of errors to return | 25 | limit=25 |
sortDirection | N | Direction to sort the results by. Accepted values are: asc, desc | desc | sortDirection=desc |
https://api.losant.com/instances/INSTANCE_ID/nodes/INSTANCE_CUSTOM_NODE_ID/errors
200 | Workflow Errors | Custom Node error information |
Retrieves information on a Custom Node
all.Instance
, all.Instance.read
, all.User
, all.User.read
, or instanceCustomNode.get
200 | Instance Custom Node | Custom Node information |
Patch
Updates information about a Custom Node
PATCH https://api.losant.com/instances/INSTANCE_ID
all.Instance
, all.User
, or instanceCustomNode.patch
The body of the request should be serialized JSON that validates against the Instance Custom Node Patch schema. For example, the following would be a valid body for this request:
"name": "My Updated Instance Custom Node",
"category": "logic"
-d '{"name":"My Updated Instance Custom Node","category":"logic"}' \
200 | Instance Custom Node | Updated Custom Node information |
Stats
Get statistics about runs for this Custom Node
/stats
all.Instance
, all.Instance.read
, all.User
, all.User.read
, or instanceCustomNode.stats
resolution | N | Resolution in milliseconds | 3600000 | resolution=3600000 |
https://api.losant.com/instances/INSTANCE_ID/nodes/INSTANCE_CUSTOM_NODE_ID/stats
200 | Workflow Statistics | Statistics for Custom Node runs |
Workflow Errors
Workflow run error information
Workflow Errors Schema
- ▶{} 8 keys
Workflow Errors Example
- "2016-06-03T00:00:00.000Z"
- "2016-06-04T00:00:00.000Z"
- 25
- "desc"
Workflow Statistics
Statistics about the runs for a given workflow
Workflow Statistics Schema
- ▶{} 7 keys
Workflow Statistics Example
- 86400000
Schema for a single Instance Custom Node
Instance Custom Node Schema
- ▶{} 25 keys
Instance Custom Node Example
- ▶{} 11 keys
- "575ed18f7ae143cd83dc4aa6"
- "My Instance Custom Node"
- "Description of my instance custom node"
Schema for the body of a Instance Custom Node modification request
Instance Custom Node Patch Schema
- ▶{} 11 keys
- 25
Instance Custom Node Patch Example
- "My Updated Instance Custom Node"
- "logic"
Success
Success Schema
Success Example
