Instance Member Actions
https://api.losant.com/instances/INSTANCE_ID/members/USER_ID
Below are the various requests that can be performed against the Instance Member resource, as well as the expected parameters and the potential responses.
Delete
Deletes an instance member
DELETE https://api.losant.com/instances/INSTANCE_ID/members/USER_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.User, instanceMember.*, or instanceMember.delete.
INSTANCE_IDID associated with the instance575ec8687ae143cd83dc4a97
USER_IDID associated with the instance member575ec8687ae143cd83dc4a94
CodeTypeDescription
200SuccessIf member was successfully deleted
CodeTypeDescription
404ErrorError if instance or member was not found
Returns an instance member
GET https://api.losant.com/instances/INSTANCE_ID/members/USER_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.read, all.User, all.User.read, instanceMember.*, or instanceMember.get.
CodeTypeDescription
200Instance MemberA single instance member
CodeTypeDescription
Patch
Modifies the role of an instance member
PATCH https://api.losant.com/instances/INSTANCE_ID/members/USER_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.User, instanceMember.*, or instanceMember.patch.
The body of the request should be serialized JSON that validates against the Instance Member Patch schema. For example, the following would be a valid body for this request:
"role": "view"
-d '{"role":"view"}' \
CodeTypeDescription
200Instance Member PatchThe modified instance member
CodeTypeDescription
  • {} 3 keys
    • "object"
    • {} 2 keys
      • {} 1 key
        • {} 1 key
      • {} 2 keys
        • "NotFound"
        • "Application was not found"
      Instance Member
      Schema for an Instance member
      Instance Member Schema
      • {} 4 keys
        • "object"
        • {} 9 keys
          • {} 2 keys
            • {} 2 keys
              • {} 3 keys
                • {} 3 keys
                  • {} 2 keys
                    • {} 2 keys
                      • {} 3 keys
                        • {} 1 key
                          • {} 1 key
                          • false
                        Instance Member Example
                        • {} 2 keys
                          • "575ef90f7ae143cd83dc4aad"
                          • "view"
                        Schema for an Instance member modification request
                        Instance Member Patch Schema
                        • {} 5 keys
                          • "object"
                          • {} 1 key
                            • {} 2 keys
                            • false
                            • [] 1 item
                            Instance Member Patch Example
                            • {} 1 key
                              • "view"
                            Success
                            Success Schema
                            • {} 3 keys
                              • "object"
                              • {} 1 key
                                • {} 2 keys
                              Success Example
                              • {} 1 key
                                • true
