Instance Organization Member Actions
https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/members/USER_ID
Below are the various requests that can be performed against the Instance Organization Member resource, as well as the expected parameters and the potential responses.
Delete
Deletes an organization member
DELETE https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/members/USER_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.User, instanceOrgMember.*, or instanceOrgMember.delete.
INSTANCE_IDID associated with the instance575ec8687ae143cd83dc4a95
ORG_IDID associated with the organization575ec8687ae143cd83dc4a97
USER_IDID associated with the organization member575ec8687ae143cd83dc4a94
CodeTypeDescription
200SuccessIf member was successfully deleted
CodeTypeDescription
404ErrorError if organization or member was not found
Returns an organization member
GET https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/members/USER_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.read, all.User, all.User.read, instanceOrgMember.*, or instanceOrgMember.get.
CodeTypeDescription
200Instance Org MemberA single organization member
CodeTypeDescription
404ErrorError if instance, organization, or member was not found
Patch
Modifies the role of an organization member
PATCH https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/members/USER_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.User, instanceOrgMember.*, or instanceOrgMember.patch.
The body of the request should be serialized JSON that validates against the Instance Org Member Patch schema. For example, the following would be a valid body for this request:
"role": "view"
-d '{"role":"view"}' \
CodeTypeDescription
200Instance Org MemberThe modified organization member
CodeTypeDescription
  • {} 3 keys
    • "object"
    • {} 2 keys
      • {} 1 key
        • {} 1 key
      • {} 2 keys
        • "NotFound"
        • "Application was not found"
      Instance Org Member
      Schema for an Instance Organization member
      Instance Org Member Schema
      • {} 4 keys
        • "object"
        • {} 10 keys
          • {} 2 keys
            • {} 2 keys
              • {} 2 keys
                • {} 3 keys
                  • {} 3 keys
                    • {} 2 keys
                      • {} 2 keys
                        • {} 3 keys
                          • {} 1 key
                            • {} 1 key
                            • false
                          Instance Org Member Example
                          • {} 2 keys
                            • "575ef90f7ae143cd83dc4aad"
                            • "view"
                          Schema for an Instance Organization member modification request
                          Instance Org Member Patch Schema
                          • {} 4 keys
                            • "object"
                            • {} 3 keys
                              • {} 2 keys
                                • {} 3 keys
                                  • {} 3 keys
                                  • false
                                Instance Org Member Patch Example
                                • {} 1 key
                                  • "view"
                                Success
                                Success Schema
                                • {} 3 keys
                                  • "object"
                                  • {} 1 key
                                    • {} 2 keys
                                  Success Example
                                  • {} 1 key
                                    • true
