Instance Organization Members Actions
https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/members
Below are the various requests that can be performed against the Instance Organization Members resource, as well as the expected parameters and the potential responses.
Returns a collection of instance organization members
GET https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/members
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.read, all.User, all.User.read, instanceOrgMembers.*, or instanceOrgMembers.get.
INSTANCE_IDID associated with the instance575ec8687ae143cd83dc4a97
ORG_IDID associated with the organization575ec8687ae143cd83dc4a97
sortFieldNField to sort the results by. Accepted values are: email, roleemailsortField=role
filterFieldNField to filter the results by. Blank or not provided means no filtering. Accepted values are: email, rolefilterField=email
filterNFilter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering.filter=my * instance
CodeTypeDescription
200Instance Organization MembersA collection of instance organization members
CodeTypeDescription
404ErrorError if instance was not found
Creates a new organization member
POST https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/members
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.User, instanceOrgMembers.*, or instanceOrgMembers.post.
The body of the request should be serialized JSON that validates against the Instance Org Member Post schema. For example, the following would be a valid body for this request:
"role": "view",
"applicationRoles": [
"resourceId": "575ef90f7ae143cd83dc4a4f",
"role": "none"
"userId": "675ed18f7ae143cd83dc4bb7"
-d '{"role":"view","applicationRoles":[{"resourceId":"575ef90f7ae143cd83dc4a4f","role":"none"}],"userId":"675ed18f7ae143cd83dc4bb7"}' \
CodeTypeDescription
200Instance Org MemberThe newly created instance member
CodeTypeDescription
  • {} 3 keys
    • "object"
    • {} 2 keys
      • {} 1 key
        • {} 1 key
      • {} 2 keys
        • "NotFound"
        • "Application was not found"
      Instance Org Member
      Schema for an Instance Organization member
      Instance Org Member Schema
      • {} 4 keys
        • "object"
        • {} 10 keys
          • {} 2 keys
            • {} 2 keys
              • {} 2 keys
                • {} 3 keys
                  • {} 3 keys
                    • {} 2 keys
                      • {} 2 keys
                        • {} 3 keys
                          • {} 1 key
                            • {} 1 key
                            • false
                          Instance Org Member Example
                          • {} 2 keys
                            • "575ef90f7ae143cd83dc4aad"
                            • "view"
                          Schema for an Instance Organization member creation request
                          Instance Org Member Post Schema
                          • {} 2 keys
                            • [] 2 items
                            Instance Org Member Post Example
                            • {} 3 keys
                              • "view"
                              • [] 1 item
                                • "675ed18f7ae143cd83dc4bb7"
                              Schema for a collection of Organization members within an instance
                              Instance Organization Members Schema
                              • {} 3 keys
                                • "object"
                                • {} 8 keys
                                  • {} 2 keys
                                    • {} 2 keys
                                      • {} 2 keys
                                        • {} 1 key
                                          • {} 1 key
                                            • {} 1 key
                                              • {} 1 key
                                                • {} 2 keys
                                              Instance Organization Members Example
                                              • {} 4 keys
                                                • [] 1 item
                                                  • 8
                                                  • "role"
                                                  • "asc"
