Instance Organizations Actions
https://api.losant.com/instances/INSTANCE_ID/orgs
Below are the various requests that can be performed against the Instance Organizations resource, as well as the expected parameters and the potential responses.
Returns the organizations associated with the current instance
GET https://api.losant.com/instances/INSTANCE_ID/orgs
all.Instance, all.Instance.read, all.User, all.User.read, instanceOrgs.*, or instanceOrgs.get.
| INSTANCE_ID | ID associated with the instance | 575ec8687ae143cd83dc4a97 |
| sortField | N | Field to sort the results by. Accepted values are: name, id, creationDate, lastUpdated | name | sortField=name |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: name | filterField=name | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my*org | |
| summaryInclude | N | Comma-separated list of summary fields to include in org summary | summaryInclude=payloadCount | |
| query | N | Organization filter JSON object which overrides all other filter params. See Advanced Instance Organization Query for more details. | query={"name":"Bob's Org","lastUpdated":"2022-01-30T17:18:11.911Z"} |
| 200 | Instance Organizations | A collection of organizations |
Create a new organization
POST https://api.losant.com/instances/INSTANCE_ID/orgs
all.Instance, all.User, instanceOrgs.*, or instanceOrgs.post.
The body of the request should be serialized JSON that validates against the Instance Owned Organization Post schema. For example, the following would be a valid body for this request:
"name": "My Org",
"limits": {
"member": 500
"auditLogEnabled": true
| 200 | Organization | The newly created organization |
Schema for advanced instance organization queries
Advanced Instance Organization Query Schema
- ▶{} 14 keys
Advanced Instance Organization Query Example
- "Bob's Org"
- "2022-01-30T17:18:11.911Z"
Schema for the body of an Organization creation request within an instance
Instance Owned Organization Post Schema
- ▶{} 13 keys
Instance Owned Organization Post Example
- "My Org"
Schema for a collection of Organizations within an instance
Instance Organizations Schema
- ▶{} 10 keys
Instance Organizations Example
- ▶{} 7 keys
- 1
- 2
- 1
- 0
- "name"
- "asc"
Organization
Schema for a single Organization
Organization Schema
- ▶{} 21 keys
Organization Example
- ▶{} 8 keys
- "575ed6e87ae143cd83dc4aa8"
- "My Organization"
- "My organization description"
- ▶[] 2 items
- ▶{} 7 keys
