Instance Sandboxes Actions
https://api.losant.com/instances/INSTANCE_ID/sandboxes
Below are the various requests that can be performed against the Instance Sandboxes resource, as well as the expected parameters and the potential responses.
Returns a collection of instance sandboxes
GET https://api.losant.com/instances/INSTANCE_ID/sandboxes
all.Instance, all.Instance.read, all.User, all.User.read, instanceSandboxes.*, or instanceSandboxes.get.
| INSTANCE_ID | ID associated with the instance | 575ec8687ae143cd83dc4a97 |
| summaryExclude | N | Comma-separated list of summary fields to exclude from user summary | summaryExclude=payloadCount | |
| summaryInclude | N | Comma-separated list of summary fields to include in user summary | summaryInclude=payloadCount | |
| sortField | N | Field to sort the results by. Accepted values are: firstName, lastName, email, id, creationDate, lastSuccessfulLogin, lastFailedLogin, failedLoginCount, lastUpdated | sortField=firstName | |
| startingAfterId | N | Exclusive ID from which to begin querying | startingAfterId=575ec8687ae143cd83dc4a97 | |
| endingBeforeId | N | Exclusive ID at which to end querying | endingBeforeId=575ec8687ae143cd83dc4a97 | |
| limit | N | How many items to return | 100 | limit=10 |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: firstName, lastName, email | filterField=firstName | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my * instance | |
| includeDeleted | N | If the result of the request should also include deleted sandboxes. | includeDeleted=true |
| 200 | Instance Sandboxes | Collection of instance sandboxes |
Instance Sandboxes
Schema for a collection of instance associated sandboxes
Instance Sandboxes Schema
- ▶{} 10 keys
Instance Sandboxes Example
- ▶{} 7 keys
- 2
- ▶[] 2 items
- 100
- "575ed70c7ae143cd83dc4aa9"
- "firstName"
- "asc"
