Private File Actions
https://api.losant.com/applications/APPLICATION_ID/privateFiles/PRIVATE_FILE_ID
Below are the various requests that can be performed against the Private File resource, as well as the expected parameters and the potential responses.
Delete
Deletes a private file or directory, if a directory all the contents that directory will also be removed.
DELETE https://api.losant.com/applications/APPLICATION_ID/privateFiles/PRIVATE_FILE_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.cli, all.Organization, all.User, all.User.cli, privateFile.*, or privateFile.delete.
PRIVATE_FILE_IDID associated with the private file575ec76c7ae143cd83dc4a96
CodeTypeDescription
200SuccessIf private file was successfully deleted
CodeTypeDescription
404ErrorError if private file was not found
Retrieves information on a private file
GET https://api.losant.com/applications/APPLICATION_ID/privateFiles/PRIVATE_FILE_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.cli, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.cli, all.User.read, privateFile.*, or privateFile.get.
urlTTLNTime in seconds that the private file url will be valid for. Only applies to private files of type 'file'. If 0, no url will be returned.900urlTTL=900
CodeTypeDescription
200File SchemaPrivate file information
CodeTypeDescription
Move
Move a private file or the entire contents of a directory
POST https://api.losant.com/applications/APPLICATION_ID/privateFiles/PRIVATE_FILE_ID/move
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.cli, all.Organization, all.User, all.User.cli, privateFile.*, or privateFile.move.
nameNThe new name of the private file or directoryname=fileA
parentDirectoryNThe new parent directory for the private file or directory to move into.parentDirectory=/new/location/here
CodeTypeDescription
201File SchemaReturns a new private file or directory that was created by the move, if a directory a job will kick off to move all the directories children.
CodeTypeDescription
Patch
Reupload a private file
PATCH https://api.losant.com/applications/APPLICATION_ID/privateFiles/PRIVATE_FILE_ID
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.cli, all.Organization, all.User, all.User.cli, privateFile.*, or privateFile.patch.
The body of the request should be serialized JSON that validates against the File Patch schema. For example, the following would be a valid body for this request:
"fileSize": 500,
"contentType": "image",
"fileDimensions": {
"width": 200,
"height": 200
-d '{"fileSize":500,"contentType":"image","fileDimensions":{"width":200,"height":200}}' \
CodeTypeDescription
201File Upload Post ResponseSuccessfully updated private file and the information needed to upload the file content
CodeTypeDescription
Upload
Uploads the private file
POST https://api.losant.com/applications/APPLICATION_ID/privateFiles/PRIVATE_FILE_ID/upload
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.cli, all.Organization, all.User, all.User.cli, privateFile.*, or privateFile.upload.
The body of the request should be a multipart form data post containing the following:
privateFileYThe content of the private file to upload``
curl -H 'Content-Type: multipart/form-data' \
-F privateFile=@localfilename' \
CodeTypeDescription
200File SchemaUpdated private file content
CodeTypeDescription
404ErrorError if file was not found
  • {} 3 keys
    • "object"
    • {} 2 keys
      • {} 1 key
        • {} 1 key
      • {} 2 keys
        • "NotFound"
        • "Application was not found"
      File Schema
      Schema for a single public or private file
      File Schema Schema
      • {} 3 keys
        • "object"
        • {} 16 keys
          • {} 2 keys
            • {} 2 keys
              • {} 2 keys
                • {} 2 keys
                  • {} 2 keys
                    • {} 2 keys
                      • {} 2 keys
                        • {} 3 keys
                          • {} 2 keys
                            • {} 2 keys
                              • {} 1 key
                                • {} 1 key
                                  • {} 2 keys
                                    • {} 2 keys
                                      • {} 2 keys
                                        • {} 1 key
                                      File Schema Example
                                      • {} 12 keys
                                        • "575ec8687ae143cd83dc4a97"
                                        • "2016-06-13T04:00:00.000Z"
                                        • "575ed70c7ae143cd83dc4aa9"
                                        • "user"
                                        • "pending"
                                        • "file.csv"
                                        • "file"
                                        • 500
                                        • "text/csv"
                                      File Patch
                                      Schema to patch a public or private file
                                      File Patch Schema
                                      • {} 3 keys
                                        • "object"
                                        • {} 3 keys
                                          • {} 1 key
                                            • {} 2 keys
                                              • {} 2 keys
                                            File Patch Example
                                            • {} 3 keys
                                              • 500
                                              • "image"
                                              • {} 2 keys
                                              Schema with the information needed to upload public or private file contents
                                              File Upload Post Response Schema
                                              • {} 2 keys
                                                • [] 2 items
                                                File Upload Post Response Example
                                                • {} 13 keys
                                                  • "user"
                                                  • "pending"
                                                  • "file.csv"
                                                  • "file"
                                                  • 500
                                                  • "text/csv"
                                                  • {} 2 keys
                                                  Success
                                                  Success Schema
                                                  • {} 3 keys
                                                    • "object"
                                                    • {} 1 key
                                                      • {} 2 keys
                                                    Success Example
                                                    • {} 1 key
                                                      • true
