Resource Jobs Actions
https://api.losant.com/applications/APPLICATION_ID/resource-jobs
Below are the various requests that can be performed against the Resource Jobs resource, as well as the expected parameters and the potential responses.
Returns the resource jobs for an application
GET https://api.losant.com/applications/APPLICATION_ID/resource-jobs
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, resourceJobs.*, or resourceJobs.get.
sortFieldNField to sort the results by. Accepted values are: name, id, creationDate, lastUpdated, lastExecutionRequested, resourceTypenamesortField=name
filterFieldNField to filter the results by. Blank or not provided means no filtering. Accepted values are: name, resourceTypefilterField=device
filterNFilter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering.filter=my*job
CodeTypeDescription
200Resource JobsCollection of resource jobs
CodeTypeDescription
Create a new resource job for an application
POST https://api.losant.com/applications/APPLICATION_ID/resource-jobs
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, resourceJobs.*, or resourceJobs.post.
The body of the request should be serialized JSON that validates against the Resource Job Post schema. For example, the following would be a valid body for this request:
"name": "Example Resource Job",
"resourceType": "device",
"queryJson": "{ \"name\": \"my device\"}"
-d '{"name":"Example Resource Job","resourceType":"device","queryJson":"{ \"name\": \"my device\"}"}' \
CodeTypeDescription
201Resource JobSuccessfully created resource job
CodeTypeDescription
  • {} 3 keys
    • "object"
    • {} 2 keys
      • {} 1 key
        • {} 1 key
      • {} 2 keys
        • "NotFound"
        • "Application was not found"
      Resource Job
      Schema for a single resource job
      Resource Job Schema
      • {} 4 keys
        • "object"
        • {} 19 keys
          • {} 2 keys
            • {} 2 keys
              • {} 3 keys
                • {} 2 keys
                  • {} 2 keys
                    • {} 1 key
                      • {} 2 keys
                        • {} 2 keys
                          • {} 2 keys
                            • {} 3 keys
                              • {} 3 keys
                                • {} 2 keys
                                  • {} 2 keys
                                    • {} 2 keys
                                      • {} 2 keys
                                        • {} 1 key
                                          • {} 1 key
                                            • {} 3 keys
                                              • {} 3 keys
                                              • false
                                            Resource Job Example
                                            • {} 11 keys
                                              • "Example Resource Job"
                                              • 60
                                              • 60000
                                              • "6328c6c026517badf9142116"
                                              • 1
                                              • "2022-09-19T19:45:04.453Z"
                                              • "6328c6c026517badf914211a"
                                              • "device"
                                              • "{ "name": "my device"}"
                                            Resource Job Post
                                            Schema for a resource job creation
                                            Resource Job Post Schema
                                            • {} 5 keys
                                              • "object"
                                              • {} 13 keys
                                                • {} 3 keys
                                                  • {} 2 keys
                                                    • {} 1 key
                                                      • {} 2 keys
                                                        • {} 2 keys
                                                          • {} 2 keys
                                                            • {} 3 keys
                                                              • {} 3 keys
        • {} 2 keys
        • {} 1 key
        • {} 1 key
        • {} 3 keys
        • {} 3 keys
        • false
        • [] 2 items
        Resource Job Post Example
        • {} 3 keys
        • "device"
        Resource Jobs
        Schema for a collection of Resource Jobs
        Resource Jobs Schema
        • {} 3 keys
        • "object"
        • {} 10 keys
        • {} 2 keys
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 1 key
        • {} 2 keys
        • {} 2 keys
        Resource Jobs Example
        • {} 6 keys
        • [] 1 item
        • 1
        • 4
        • "name"
        • "asc"
        • "575ec8687ae143cd83dc4a97"
