User API Tokens Actions
https://api.losant.com/me/tokens
Below are the various requests that can be performed against the User API Tokens resource, as well as the expected parameters and the potential responses.
Returns the API tokens for a user
GET https://api.losant.com/me/tokens
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.User, all.User.read, userApiTokens.*, or userApiTokens.get.
sortFieldNField to sort the results by. Accepted values are: name, status, id, creationDate, lastUpdated, expirationDatenamesortField=name
filterFieldNField to filter the results by. Blank or not provided means no filtering. Accepted values are: name, statusfilterField=key
filterNFilter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering.filter=my*token
CodeTypeDescription
200API TokenCollection of API tokens
CodeTypeDescription
Create a new API token for an user
POST https://api.losant.com/me/tokens
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.User, userApiTokens.*, or userApiTokens.post.
The body of the request should be serialized JSON that validates against the API Token Post schema. For example, the following would be a valid body for this request:
"name": "My New API Token",
"expirationDate": "2017-06-13T04:00:00.000Z",
"scope": [
"all.Application"
"status": "active"
-d '{"name":"My New API Token","expirationDate":"2017-06-13T04:00:00.000Z","scope":["all.Application"],"status":"active"}' \
CodeTypeDescription
201API TokenThe successfully created API token
CodeTypeDescription
API Token
Schema for a single API Token
API Token Schema
  • {} 3 keys
    • "object"
    • {} 15 keys
      • {} 2 keys
        • {} 2 keys
          • {} 2 keys
            • {} 2 keys
              • {} 2 keys
                • {} 2 keys
                  • {} 2 keys
                    • {} 3 keys
                      • {} 2 keys
                        • {} 2 keys
                          • {} 2 keys
                            • {} 2 keys
                              • {} 2 keys
                                • {} 2 keys
                                  • {} 2 keys
                                API Token Example
                                • {} 13 keys
                                  • "575ec7417ae143cd83dc4a95"
                                  • "575ed70c7ae143cd83dc4aa9"
                                  • "user"
                                  • "575ec8687ae143cd83dc4a97"
                                  • "application"
                                  • "My API Token"
                                  • "2016-06-13T04:00:00.000Z"
                                  • "2017-06-13T04:00:00.000Z"
                                  • [] 1 item
                                    • "active"
                                    • "the_actual_token_string"
                                  API Token Post
                                  Schema for the body of an API Token creation request
                                  API Token Post Schema
                                  • {} 5 keys
                                    • "object"
                                    • {} 5 keys
                                      • {} 3 keys
                                        • {} 2 keys
                                          • {} 2 keys
                                            • {} 3 keys
                                              • {} 2 keys
                                              • false
                                              • [] 1 item
                                              API Token Post Example
                                              • {} 4 keys
                                                • "My New API Token"
                                                • [] 1 item
                                                  • "active"
                                                • {} 3 keys
                                                  • "object"
                                                  • {} 2 keys
                                                    • {} 1 key
                                                      • {} 1 key
                                                    • {} 2 keys
                                                      • "NotFound"
                                                      • "Application was not found"
