ApplicationExperience
Table: Update Row Node
The Data Table: Update Row Node allows a workflow to update an existing row in a Data Table inside the current application, and optionally add the updated row to the current workflow payload.
Table Update Row Node
To find the row to update, the node requires both a data table to be selected, and by default the id of the row to update. Both fields are templatable, and so supports finding a row based on the current workflow payload. The example below is doing exactly that, and is referencing the field data.body.rowId on the workflow payload.
Table Update Row Node Configuration
As well as looking up the row to be updated by the id template there is also the option, “Select Row By… Query”, to search for the row. Building your query within the node is nearly identical to building a query within the table browsing interface. The only difference is, when building a query within the node, you may use string templates for each property and value – or, if building an advanced query, you may use a JSON template. When selecting a row by query there is also the option to “Insert row if it does not exist” by selecting the checkbox below your query.
Note: Only the first row returned by the query will be updated.
Table Update Row Node Query
There are three different ways to configure input data for the Table: Update Row Node - “JSON Template”, “Payload Path”, and “Individual Fields”. The first two are more complicated to use, but are very powerful because they give you full control over the row being updated, while the third choice is the more common option for simple situations.
For “JSON Template”, the input must be a JSON template string that can be parsed into a JSON object that validates against the Data Table Row Insert/Update schema. For “Payload Path”, the input must be a payload path that points to an object on the current workflow payload that, again, validates against the Data Table Row Insert/Update schema. In both of these cases, this means it must be an object where the keys of the objects are the column names of the data table, and the value for each key is the value for that column in the new row. Columns that are not specified will retain their current values on the row.
Table Update Row Node Individual Fields
For “Individual Fields”, the most common method to use and the one shown in the example above, the row is broken into multiple fields that can be filled in using individual string templates. In this case, no columns are required - not doing anything with a column will just not update that column on the row. You can choose to set a value for a column, or to clear the value for a column. In the example above, the node is just setting a new value for the phone number column on the row and leaving the other columns alone.
Table Update Row Node Result
Optionally you can provide a payload path in the “Result Path” field so that the updated row can be placed at that path on the current workflow payload. In the case of a successful row update operation, this will be the updated row object. In the case of a failed row update, this will be an object of the errors that occurred trying to update the row.
For instance, given the example node configuration in the screenshots above, this is a possible result for a successful row update:
    "body": {
      "rowId": "598ddf39ae2e7b0007fb7bcf",
      "newPhone": "867-5309",
    "updateResult": {
      "name": "Bob",
      "phone": "867-5309",
      "id": "598ddf39ae2e7b0007fb7bcf",
      "updatedAt": "2017-08-11T16:45:45.861Z",
      "createdAt": "2017-08-10T15:34:33.712Z"
And again, given the example above, this is a possible result for a failed row update where the given row ID did not exist:
    "body": {
    "updateResult": {
        "type": "NotFound",
        "message": "Data Table Row was not found"
